#41 |
Great work. When I was doing all my tape measure engineering, I figured out that if my adapter between the rear-most face of the Jeep T5 and the front face where the rear clamshell bolts to was about 2-1/8" (going on memory only), I could use a stock 33/34 Torque-tube and driveshaft without having to shorten anything. Apart from the center section surgery required, it would be close to bolt-in.
The Jeep T5 shifter is about 7" more rearward than stock - again, I'm going on memory - I haven't fiddled with any of my early Ford stuff in a few years as everything has been on hold based on life events. Good info, great conversion, and it sounds far more complicated than it is once you solve the challenge of the spline adapter & seal plate...it's really pretty simple. I think I also figured out that using the Jeep 5th gear with the Astrovan cluster came up with an aggressive .59 OD ratio, which allowed a nice cruising RPM with an early Ford rear stock gear assembly.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
#42 |
I apologize to the guys that did all of this amazing work in that I am just now reading of it and just now bestowing my sincere praise of your efforts and results.
I don't normally look at posts that reflect modified vehicles. Regardless of the fact I am a purist, I so very much appreciate any venue wherein the "players" have shown keen insight, intellect and execution. I have an engineering and tool making background so feel I can offer with confidence that these guys went to great efforts to make this happen at the level of quality depicted. Congratulations to a job well done!
#43 | |
![]() Quote:
It is the 59a-350. Heard
Do I look like I have a plan B? |
#44 |
Ernie,
You are correct I believe that a stock 33/34 tube might have worked. It would be VERY close and I almost went this way, but I thought since I already had the '35 tt/shaft, I'd modify it. Dick could probably provide some input on this. And you are correct, it sounds WAY more complicated than it really is. If I can do it, almost anyone on the Barn can do it. After all, I'm just a redneck with a welder. And I ain't very good with it either.... Also, you should know that your old T5 posts are what really started this whole thing so I'm puttin' part of the blame on you! Heard
#45 |
Thanks ! We should be in St.Augustine for Jan-Feb. I would like to drop by on the Harley to see your work if that is OK.
John |
#46 |
#47 | |
![]() Quote:
I'm not surprised that Flat Ernie was already on to this nifty bit of old Ford trivia, 'cuz I was aware several years ago that Ernie had the desire to eventually adapt one of these Jeep-influenced T5s into his '40 coupe with a blown French flathead, along with it's T-tube and banjo rear end. Ernie's sweet coupe sure would be a "sleeper" in this guise. Obviously, Ernie had already done quite a bit of engineering and homework on his own. As many of you will note, Flat Ernie has long been recognized on the FordBarn and the HAMB as the "Go-To" T5 guru. As Ernie and Heard noted, this project is certainly much easier to accomplish than it sounds like initially. I'm hoping that this thread has at least encouraged a few to consider this mod on their own cars. DD |
#48 | |
![]() Quote:
#49 |
Hmmm.......I just went out there and measured my new shortened torque tube because I wanted to see how close I was to my initial 61 7/8. It is now actually exactly 62" overall.
Please don't use that 62" number though. Make your own measurements. Your results may vary depending upon whose adapters you use as well as other subtle differences.
#50 |
That is really nice... you should sell the kit as it would do a great job.... were i just starting my 41 Pu conversion to T5 i would buy one, rather that do all i did to convert mine to open drive, in a New York Minute.....
#51 |
You don't need the whole rear end. Just the torque tube, and maybe the drive shaft from a V8 rear end. Remember, the 4-cylinder parts are 1-1/2" shorter. DD
#52 |
When I was working on mine a long time ago, I actually acquired a 33/34 torque-tube and driveshaft. My understanding is that it would all bolt up to the later rear, but would need the oil drain hole drilled or aligned...
Unfortunately, a couple of military moves, then a bunch of life got in the way. My old '40 is in storage and hasn't run in a few years. I'm working on getting into a new place here in the new year and hopefully consolidating all my stuff in one spot. Maybe then I can work through my projects and get back to the '40...
#53 |
Great thread. Thanks for sharing all the hard work!
#54 | |
![]() Quote:
#55 | |
![]() Quote:
#56 | |
![]() Quote:
#57 |
Great job ,Well thought out .Ted
#58 |
Good job DD and Heard. Wish we had a tech section here for filing these type of threads, but I plan to bookmark this one for future reference.
#59 |
Heard,
Keep us clued in on your clutch linkage too if you will. I'd be real interested in seeing that. Thanks. |
#60 |
Ted,
Will do. I'm also working on the parking brake stuff since that has to be sorted out. Heard
