Old 08-04-2016, 10:28 AM   #1
37 Cab
37 Cab's Avatar
Default 37 floor pictures
I am replacing the floor mat in my Cabriolet because the old one is a poor fit and I think the shifter boot is not right. Also, Was there a mat that extended past the front edge of the seat in a coupe or cabriolet? Mine is bare metal.
Any pics you can offer are much appreciated.
Tommy
37 Cab is offline   Reply With Quote
Old 08-04-2016, 12:45 PM   #2
DavidG
DavidG's Avatar
Default Re: 37 floor pictures
Here's a couple of photos of the correct mat for a '37 cabriolet. No boot was used on the shift lever housing.
Originally there were separate floor mats for behind the front seat and in front of the bottom rumble seat cushion. Unfortunately I don't have photos of those in this computer or likely elsewhere. I can take some, but it will take some if you wish. It may take several weeks.
DavidG is online now   Reply With Quote
Old 08-04-2016, 02:27 PM   #3
37 Cab
37 Cab's Avatar
Thank you David. I thought there should be rear mats but have had no luck finding them. Where did you get yours?
Tommy
Old 08-04-2016, 03:01 PM   #4
DavidG
DavidG's Avatar
A few of the rear mats were reproduced years ago, but I'm reasonably sure that no one is making them at present. All of the mats in my car are the originals. I repaired them using pieces from the remnants of a standard Tudor rear mat and then they were painted with SEM in the original Benton Gray color.
Old 08-04-2016, 04:04 PM   #5
37 Cab
37 Cab's Avatar
They look great. I will see what I can do with using the mat I am removing. Maybe I could order a rear mat for a sedan and cut it up? My car is driver quality.
Tommy
Old 08-04-2016, 04:54 PM   #6
DavidG
DavidG's Avatar
If they are available, it might take two of the sedan rear mats to make up the two mats that you need.
Old 08-04-2016, 07:57 PM   #7
37 Cab
37 Cab's Avatar
Lebaron bonney and a couple others I checked do not have reproduction rear mats. Looks like I am on my own here. Will probably order another front mat and see what I can do.
Tommy
