Old 07-29-2016, 03:40 PM   #1
HOTRODRON
Default 1934 ford glove box hinge
Hey guys i replaced the hinge on my 34 ford but now the door sets to high and when open bottom edge hits dash before it can open what did i do wrong using drake repair parts
HOTRODRON is offline   Reply With Quote
Old 07-30-2016, 06:09 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1934 ford glove box hinge
Maybe the hinge pin is not through all of the holes properly.
Old 07-30-2016, 10:00 AM   #3
Juergen
Either the hinge on the door is bent down or the tabs on the dash are bent up. If you got a repro hinge, I suspect the latter. See if the tab if flat against the bottom of the dash before it goes 90 degrees up.
Juergen is offline   Reply With Quote
Old 07-30-2016, 10:01 AM   #4
HOTRODRON
Anyone have any photos of how this part is installed in a 34 ford dash
Old 07-30-2016, 11:10 AM   #5
Terry,OH
Terry,OH's Avatar
do you have a photo of how you installed it?
Old 07-30-2016, 11:30 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Does this help? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-30-2016, 07:02 PM   #7
HOTRODRON
Thanks for the photo i was mounting it on bottom of the glovebox linner as there were no holes in bottom of the dash someone filled them in
Old 07-31-2016, 06:05 AM   #8
Terry,OH
Terry,OH's Avatar
If the two small brackets are on the bottom of the dash they should have holes for the hinge pin as well as the two ears on the hinge screwed to the glove box door. Yes the pin is mounted to the bottom of the glove box. On my car the large U shape is on the RH side (toward door) of the glove box.
Old 08-03-2016, 11:27 PM   #9
HOTRODRON
Thanks ford barners got the door put on the dash thanks agin
