The Ford Barn
-   -   1934 ford glove box hinge (https://www.fordbarn.com/forum/showthread.php?t=201532)
HOTRODRON 07-29-2016 03:40 PM
Hey guys i replaced the hinge on my 34 ford but now the door sets to high and when open bottom edge hits dash before it can open what did i do wrong using drake repair parts
Terry,OH 07-30-2016 06:09 AM
Re: 1934 ford glove box hinge
Maybe the hinge pin is not through all of the holes properly.
Juergen 07-30-2016 10:00 AM
Either the hinge on the door is bent down or the tabs on the dash are bent up. If you got a repro hinge, I suspect the latter. See if the tab if flat against the bottom of the dash before it goes 90 degrees up.
HOTRODRON 07-30-2016 10:01 AM
Anyone have any photos of how this part is installed in a 34 ford dash
Terry,OH 07-30-2016 11:10 AM
do you have a photo of how you installed it?
V8COOPMAN 07-30-2016 11:30 AM
Does this help? DD
https://www.fordbarn.com/forum/attach...7&d=1341218299
HOTRODRON 07-30-2016 07:02 PM
Thanks for the photo i was mounting it on bottom of the glovebox linner as there were no holes in bottom of the dash someone filled them in
Terry,OH 07-31-2016 06:05 AM
If the two small brackets are on the bottom of the dash they should have holes for the hinge pin as well as the two ears on the hinge screwed to the glove box door. Yes the pin is mounted to the bottom of the glove box. On my car the large U shape is on the RH side (toward door) of the glove box.
HOTRODRON 08-03-2016 11:27 PM
Thanks ford barners got the door put on the dash thanks agin
