Old 07-13-2016, 06:17 PM   #1
Jakno
Jakno's Avatar
Default 35 steering column electrical
The electrical connection hub on the bottom of my 35 Ford pickup steering column is being replaced/repaired. Having trouble with attaching the wire bail that holds the two housing halves to the steering column. Can't seem to find any projections or "ears" for the bail loops to hook over. I have both a new after market bail and what I think is the original bail, neither of which work.
Can you tell from the picture if I'm missing something on the steering column for attachment points
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 07-13-2016, 06:31 PM   #2
JSeery
JSeery's Avatar
Default Re: 35 steering column electrical
Do these help any? These are 37 and later.
Old 07-13-2016, 06:44 PM   #3
Terry,OH
Terry,OH's Avatar
It is a very common swap to fit a 37-39 steering box to the 35. This may be what you have.
Old 07-13-2016, 07:30 PM   #4
Jakno
Jakno's Avatar
Mr. Seery and Terry. You just refreshed what memory I have left. The steering box is actually a 1937 model and ihe reason my 1935 bail doesn't fit. I'm pretty sure I can modify my bail now to work with the 37 box. Thanks for helping me out.
Old 07-13-2016, 08:03 PM   #5
Don Rogers
Don Rogers's Avatar
Janko, Here are a couple of pictures that should help comparing a 35/36 bail with a 37 bail. Your light switch housing will only work with these designs.
Don Rogers is offline   Reply With Quote
Old 07-13-2016, 08:04 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Hi Jake. I just went out in my shop to look, I have some shock links but there not like the ones need. I wish they were, you could have them. Is that you and Chris up on top of that pole on your Avatar. Walt
Old 07-13-2016, 08:24 PM   #7
Jakno
Jakno's Avatar
Walt, thanks for looking for the shock link. There's a salvage yard nearby that I think might have some. The picture is on Swan's Island last summer. Chris is on the pole, not me.
