I have done a search and read several posts on this subject. Some say I need to bench bleed others say it's not needed. Please help. I have a new '40 style master cylinder from C&G Ford. Should I bench bleed or not?
I do before install.
I've never done it.
NO generally not on a single system , DO not push the pedal all the way to the floor when bleeding when you install.. Also speed bleeders are your best friend right about now.
"Came too close to dying to stop living now!" |
Whether you really NEED to or not, I still do. It's just less air to pump out through the lines.
As soon as it's installed, you fill it and start pumping fluid thru. Bench bleed seems redundant. |
The one I got from Napa needed to be
Ford |
No. Lines & wheel cylinders are prolly gonna be full of air anyway. Why bother!?
Jack E/NJ |
I've never bench bled a single one - on any car. Seems to me to be great way to get brake fluid all over the engine compartment (or frame) - that crap eats the heck out of any paint you might have.
Not saying it is a bad idea, but by the time I'm putting in a new master cylinder, I've usually screwed with the brake cylinders or calipers . . . but maybe that is just me! It can't hurt yah - but might make a good mess! |
I don't bench bled them.
Some master/slave cylinder with a remote resiovour are an example of a system that needs to be bench bled. As was used on B 25 towmotor clutch.
Bruce
Works good Lasts long time |
Thanks everyone. I am going to install it with out bench bleeding.
#13 |
After you install and fill with fluid, leave the cap off and gently press on the brake pedal a few times. You will see bubbles escaping and that should "bleed" the cylinder just fine. Then do the lines.
