The Ford Barn
-   -   Do I need to bench bleed '40 master cylinder (https://www.fordbarn.com/forum/showthread.php?t=189819)
firerod 02-21-2016 10:35 PM
I have done a search and read several posts on this subject. Some say I need to bench bleed others say it's not needed. Please help. I have a new '40 style master cylinder from C&G Ford. Should I bench bleed or not?
texas webb 02-21-2016 10:43 PM
Re: Do I need to bench bleed '40 master cylinder
I do before install.
Lawson Cox 02-21-2016 10:56 PM
I've never done it.
Talkwrench 02-21-2016 11:44 PM
NO generally not on a single system , DO not push the pedal all the way to the floor when bleeding when you install.. Also speed bleeders are your best friend right about now.
willowbilly3 02-22-2016 06:42 AM
Whether you really NEED to or not, I still do. It's just less air to pump out through the lines.
moefuzz 02-22-2016 10:32 AM
I never have.
As soon as it's installed, you fill it and start pumping fluid thru.
Bench bleed seems redundant.
jacob smith 02-22-2016 09:52 PM
The one I got from Napa needed to be
Jack E/NJ 02-22-2016 09:58 PM
No. Lines & wheel cylinders are prolly gonna be full of air anyway. Why bother!?
Jack E/NJ
Bored&Stroked 02-22-2016 10:00 PM
I've never bench bled a single one - on any car. Seems to me to be great way to get brake fluid all over the engine compartment (or frame) - that crap eats the heck out of any paint you might have.
Not saying it is a bad idea, but by the time I'm putting in a new master cylinder, I've usually screwed with the brake cylinders or calipers . . . but maybe that is just me!
It can't hurt yah - but might make a good mess!
JSeery 02-22-2016 10:29 PM
I don't bench bled them.
cmbrucew 02-22-2016 11:00 PM
Some master/slave cylinder with a remote resiovour are an example of a system that needs to be bench bled. As was used on B 25 towmotor clutch.
Bruce
firerod 02-23-2016 09:47 AM
Thanks everyone. I am going to install it with out bench bleeding.
39topless 02-23-2016 11:04 AM
After you install and fill with fluid, leave the cap off and gently press on the brake pedal a few times. You will see bubbles escaping and that should "bleed" the cylinder just fine. Then do the lines.
