Old 11-20-2015, 09:28 AM   #1
green50
green50's Avatar
Default Starter Bendix/Drive Bolts
I recently had an issue with the starter in the '50. I found that one of the drive bolts had come loose and fell off. It seems that someone replaced it with a regular grade 5 bolt and possibly a used locking tab. My question is, when I replace the drive bolts and locking tabs (have NOS replacements) should I use blue loctite 242 for extra insurance. Thanks
Gene
green50 is offline   Reply With Quote
Old 11-20-2015, 09:39 AM   #2
42merc
42merc's Avatar
Default Re: Starter Bendix/Drive Bolts
My experience has been that no Locktite is required when properly tightened.
Most Bendix bolt Problems come from bolts not installed tight enough.
But then, blue Locktite can't hurt.
42merc is offline   Reply With Quote
Old 11-20-2015, 04:32 PM   #3
koates
Hi there. Just use the correct Bendix/Ford bolts for the application and fit new locking tab washers and not reused ones. There are several bolt types so its important to use the correct ones for your drive. I have never used Locktite when assembling these drives. Been doing it for over 50 years. Regards, Kevin.
koates is offline   Reply With Quote
Old 11-20-2015, 05:49 PM   #4
green50
green50's Avatar
Thanks Kevin, I do have the correct NOS bolts and locking tabs.
Gene
