Old 11-14-2015, 05:37 PM   #1
imacrazy
Default imacrazy
What is the best 6 volt flasher for a good strong flash? the one I have wants to flash so slow you would be turned before it flashes.
Thanks, Sure do enjoy all of the tips on this forum.
Bill
imacrazy is offline   Reply With Quote
Old 11-14-2015, 06:15 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: imacrazy
An old stock 535 [ if 3 prong] should work fine. New ones are pretty much junk.
What are you using for lights ? Have you tried using lower wattage/candle power bulbs in the front ?
That is, assuming the contacts/connections/grounds are all good.
More info would also be helpful.
Old 11-14-2015, 11:29 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Default Best flasher
Bill
A lot depends on the bulbs, Low wattage or LED slow or none. High wattage makes the flash go faster.
I would look for a solid state flasher, they don't care what kind of bulbs you have.
