Old 05-31-2015, 04:37 PM   #1
Ralph Moore
Ralph Moore's Avatar
Default Secret to acorn nuts?
Been trying to put chrome acorns on my head bolts, and I'm having a heck of a time. They are all going on difficult, no foil needed, but some are splitting, and there's one bolt in particular that I've destroyed two acorn nuts on.
I'm using a piece of UHMV as to not dent the nuts. Is there any easy way to do this?
Ralph Moore is offline   Reply With Quote
Old 05-31-2015, 04:45 PM   #2
oldskool
oldskool's Avatar
Default Re: Secret to acorn nuts?
are you sure you have the correct size acorn nuts they should be 11/16 but they come in 5/8 9/16 as well. try them on a 5/8 bolt and see
oldskool is offline   Reply With Quote
Old 05-31-2015, 07:15 PM   #3
Ralph Moore
My head bolts are new 11/16" from Van Pelts. Nuts must be same cause I tried them on a 5/8" bolt, way too loose.
Chrome acorn Nuts are from Speedway.
Old 05-31-2015, 07:43 PM   #4
bchrismer
bchrismer's Avatar
Interested to see your solution, because the ones that I got from Speedway are too tight to fit without the use of semi-destructive install methods.
HotRodHundred.com
Reliability Runs
It's about the drive!!!
StreetRodder.Net The FUN is in the RUN!!!
bchrismer is offline   Reply With Quote
Old 05-31-2015, 08:16 PM   #5
jake197000
how about using covers.
jake197000 is offline   Reply With Quote
Old 05-31-2015, 08:46 PM   #6
TJ
TJ's Avatar
The little Chinese guy that made them forgot we don't use the metric system.
Old 05-31-2015, 09:01 PM   #7
Bassman/NZ
Bassman/NZ's Avatar
I destroyed a Speedway set. I bought a set from another supplier and they were perfect. I hold them on with a dab of silicone.
Bassman/NZ is offline   Reply With Quote
Old 05-31-2015, 09:17 PM   #8
f1builder
i just use a bit of electrical tape to cover the stud and overlap a little bit and they snug right up and stay on and are easy to pop off.
f1builder is offline   Reply With Quote
Old 05-31-2015, 09:17 PM   #9
f1builder
i meant cover the stud bold nut (early v8).
Old 05-31-2015, 09:20 PM   #10
Ralph Moore
I'm not having a problem with them falling off, but going on the first place.
Bassman, do you remember where you got them from?
Old 05-31-2015, 11:49 PM   #11
Ralph Moore
PITA, but I took a dremel tool and carved them out a bit( still tough going on),
Gee I only have 24 more to go
I would like a source for some proper fitting ones though, then I can take all these to the firing range and have fun with my .22!
Old 06-01-2015, 02:10 AM   #12
Graeme / New Zealand
Graeme / New Zealand's Avatar
I just gave them a tweak from one side too the other with a set of "nut F**Kers" (multi grips) on the open end. This hardly marks them. Now they're tight enough to stay on but easy enough to pull off if you have to.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 06-01-2015, 02:51 AM   #13
Bassman/NZ
Bassman/NZ's Avatar
I think they were Macs.... my memory's not too good these days.....
Old 06-01-2015, 09:37 AM   #14
dean333
dean333's Avatar
Send a message via Yahoo to dean333
I didn't like mine, gave away a whole bag. I prefer the stock original look on the whole car.....36 Fordoor.
Tim Carlig
dean333 is offline   Reply With Quote
Old 06-01-2015, 10:35 AM   #15
zzlegend
zzlegend's Avatar
Ralph, I had a first set that went on just nice and snug. Don't remember where I bought them. I just installed a second set on another engine that slide on and off easily. I had to put a dab of silicone on them to hold them in place. This is where I got them, if this helps you. Just my 2 cents.
http://www.ebay.com/itm/Flathead-for...item43dd4a3864
zzlegend is offline   Reply With Quote
Old 06-01-2015, 10:43 AM   #16
deuce_roadster
deuce_roadster's Avatar
The ones that came with my ARP studs work perfectly and are deep enough they don't bottom out. These are not caps but actual acorn nuts.
Old 06-01-2015, 01:23 PM   #17
flatheadmurre
flatheadmurre's Avatar
If you dont like Epray you find him at offyonline.com
Old 06-01-2015, 04:27 PM   #18
Angledrive
Angledrive's Avatar
Speedway nut covers are plastic and do not work very well. Buy a set of chrome steel nut covers from Bob Drake and you will be happy.
Angledrive is offline   Reply With Quote
Old 06-14-2015, 11:22 AM   #19
Ralph Moore
Update in the acorns. My Speedway ones were metal, but fit was terrible.
Took ZZLegend and flatheadmurre's advice and ordered from Offyonline.
Worked great! Tiny bit of silicone, and I did one side in about five minutes!
Now I wish I had ordered his intake set.
Old 06-24-2015, 02:42 PM   #20
lonewolf
Another quality speedway product......i quit buying ANYTHING that is speedway brand they make nothing but crap....i try not to buy from them period..but to each his own
lonewolf is offline   Reply With Quote
