Old 05-31-2015, 11:20 AM   #1
dgkipp
Default No fuel pressure after 20 mins driving
Hi guys, this has been driving me crazy for months. After 20 mins. Driving I have no fuel pressure. Installed 3 carb manifold with 97s. Installed a carter elec fuel pump in the rear at the tank with filter at the suction side. Preset the fuel pressure at 2 1/2 pounds. Runs great for 20 mins then fuel pressure starts dropping to 0. Installed a return fuel line to fuel tank from fuel block.no better.
Checked carb temp when pressures sure is 0 and it is only 97 degrees. Engine temp 160 degrees. This is the second carter pump. Tried it with the fuel cap off .still drops to 0. Any one have any ideas. Thanks..
dgkipp is offline   Reply With Quote
Old 05-31-2015, 11:30 AM   #2
Binx
Default Re: No fuel pressure after 20 mins driving
Maybe check the supplied voltage and amp draw at the pump during start-up then again after 20 min.
Lonnie
Binx is offline   Reply With Quote
Old 05-31-2015, 11:52 AM   #3
uncle max
uncle max's Avatar
If it's one of those dial regulators sold by auto parts stores, junk it and get a decent regulator.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 05-31-2015, 12:32 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
Is the gas cap vented?
Ken/Alabama is online now   Reply With Quote
Old 05-31-2015, 12:51 PM   #5
Lawson Cox
Lawson Cox's Avatar
Hook up a mechanical gauge and see what the pressure is.
Old 05-31-2015, 12:58 PM   #6
f1builder
with 3 carbs you might want to move it up to 3 or 3 1/2 and try that for a while. i run 2 97's and 2 1/2 is a little less than it wants, especially in 2d to 3rd gear at around 60, it stumbled a bit at 2 1/2 and the pressure dropped off to almost 0. also tuned the idle adjustment on the front carb so it is opened up about 3 turns instead of 1 1/2 or 2. just tinker with it till it gets where you want it.
f1builder is offline   Reply With Quote
Old 05-31-2015, 01:27 PM   #7
19Fordy
19Fordy's Avatar
Right after the 20 minutes when it stops running, disconnect the fuel line at the carburetor and see if the fuel pump is pumping fuel. If your fuel pressure gauge is one of those after market 'liquid filled" gauges, drain the liquid out of it and it will probably show a reading.
That's what I did to my liquid filled gauge. Even though it read "zero" it was really pumping fuel. Don't know what regulator you're using, but i found the little Holley regulators to work good.
19Fordy is online now   Reply With Quote
Old 05-31-2015, 01:29 PM   #8
dgkipp
Used two new holley regulators
Old 05-31-2015, 01:31 PM   #9
dgkipp
Hooked up 2 new liquid gauges. Both the same results
Old 05-31-2015, 01:31 PM   #10
sidevalve8ba
sidevalve8ba's Avatar
When the fuel pressure drops to 0 does the engine die out from lack of fuel?
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 05-31-2015, 01:32 PM   #11
dgkipp
Gas cap is vented. Even tried it with no gas cap.
Old 05-31-2015, 01:33 PM   #12
dgkipp
Yes starts stumbling.
Old 05-31-2015, 01:43 PM   #13
36 flathead
sounds like garbage in the fuel tank.
36 flathead is offline   Reply With Quote
Old 05-31-2015, 02:04 PM   #14
Joe Immler
I agree with 36 flathead. I had a same situation. Found there was a piece of masking tape that floated around in the tank and it was eventually attracted to the fuel line and stalled the engine out. Of course, after stopping it started floating around again. Oh yeah, how the tape got there is a complete mystery ! You should be able to remove the gas gauge unit on the top of the tank and look around with a bright flash light. I could see nearly every part of the bottom of the tank. Let us know the answer to your problem.
Joe Immler is offline   Reply With Quote
Old 05-31-2015, 02:36 PM   #15
Lanny
Lanny's Avatar
If the tank isn't new, or if it's original, and hasn't been professionally cleaned' then
I would change the fuel filter fairly often.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 05-31-2015, 03:17 PM   #16
19Fordy
19Fordy's Avatar
Drain the liquid from those gauges and try again to see if you still get a zero reading.
Old 05-31-2015, 03:38 PM   #17
30-9
He said car stumbles - I doubt gauges have anything to do with it
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 05-31-2015, 03:56 PM   #18
Tony, NY
Lonnie
I agree. If you have an wire connection hanging on by a few strands it will quit after a while.
Tony, NY is offline   Reply With Quote
Old 05-31-2015, 04:42 PM   #19
George/Maine
George/Maine's Avatar
I would move the filter to inlet at fuel block. Then blow back fuel line with 40 lbs. air. to tank.
George/Maine is offline   Reply With Quote
Old 05-31-2015, 05:19 PM   #20
sidevalve8ba
Yep, I gotta wonder about that, too.
