#61 |
![]() Your Very Welcome Mitch. I Got The Same Filters Wix 33039, I Like Them Because The Fuel From The Tank Go Thru Them First, Not Like The Org Ones Where The Fuel Goes Thru The Outside First ,I Think This Is A Better Way To Filter Fuel. But Will The Holes On The Top Of The Wix Filter Get Block Off By The Bowl Cork Gasket ?? I Do Have A Hand Punch, Do You Think It Would Be A Good Idea>>> To Make The Holes A Little Bigger On The Inboard Side ? Joe |
#62 | |
![]() Quote:
no modifications or reengineering is needed ![]() |
#63 |
Has anyone put a magnet in the tank?
#64 |
I placed a 4 inch speaker magnet by my gas outlet of my tank, I think it's helped keep the rust out of carb. I also placed a filter or trap from one of the parts suppliers in the sediment bowl, every little bit helps.
#65 |
I went to my local auto parts house, not a NAPA store and asked to cross reference the NAPA 3039 filter and they came up with a WIX 33039 that works fine. It also has a gasket built onto the top of it that seals to the glass bowl just fine. The gasket has a row of small holes around the outside of it to allow fuel to enter. I asked about a small magnet for inside the bowl and the guy ripped a refrigerator magnet off his cabinet and told me "There, free, cut as many as you like," So I did cut one and have material for more if I like the outcome.
#66 | |
Jack, excuse his dumb question. I've found some 1/4" x 1/4" x 1" magnets and some Disc magnets 3/4" x 1/16". Would the first fit or which would be yur choice. thanks, Skibb (Home of the Rustest Tank on the Model A Highway) |
#67 | |
![]() Quote:
Thanks Harley03joe |
#68 | |
![]() Quote:
Takes Two Hand To Pull Them Apart If You Can, I Can't So I Slide Them Sideways Till They Come Apart, There Very Very Strong, I Have 2 On The Outside Of My Fuel Tank In The Cab On My 31 |
#69 |
Ok Mitch I See The Holes, Thanks Again For The Info.
Mitch Check This Place For Filters Ok Thanks Again Joe http://www.discountfleetsupply.com Discount Fleet Supply - Heavy Duty Fleet Products - Buy Online! - www.DiscountFleetSupply.com |
#70 |
#71 |
#72 | |
![]() Quote:
for the link yes 2.90 is cheap but the shipping is over 10.00... i get them from my shop jobber for 5.43 no shipping ,,no tax |
#73 | |
![]() Quote:
Jack has not signed on the barn since 9/8/14 @ 9:32 a/m so you might be waiting a while for your answer... |
#74 |
#75 |
