Old 02-08-2015, 02:12 PM   #1
barkleydave
barkleydave's Avatar
Default Installation of Temp Gauge
I now see there are other posts regarding this topic.
One question... Is the APCO gauge mechanical or electronic?
Thanks
Last edited by barkleydave; 02-08-2015 at 02:39 PM. Reason: previously posted topic
barkleydave is offline   Reply With Quote
Old 02-08-2015, 02:34 PM   #2
daveymc29
daveymc29's Avatar
Default Re: Installation of Temp Gauge
May I piggy back on your question and ask about a temp. gauge with a tube from the sensor to the gauge? How can I repair it if need be, it apparently doesn't indicate. I'm going to pull the sensor and submerge it in hot water. If it works I'm fine, but if there is no rise in the gauge, what next? Thanks
daveymc29 is offline   Reply With Quote
Old 02-08-2015, 02:34 PM   #3
Ford1931
Ford1931's Avatar
That is not a wire, it is a tube that senses pressure with heat. Once you cut it, you now have a wall ornament.
Ford1931 is offline   Reply With Quote
Old 02-08-2015, 02:40 PM   #4
barkleydave
That's what I thought! Just like my MGA gauge
need a pretty big hole to run the cable through the fire wall... ick.
Old 02-08-2015, 02:57 PM   #5
edmondclinton
Thanks
BD, did you say that you installed the sensor probe in the inlet side of the block?
edmondclinton is offline   Reply With Quote
Old 02-08-2015, 03:21 PM   #6
HoarseWhisperer
HoarseWhisperer's Avatar
http://www.ply33.com/Repair/tempgauge
If you are successful with this repair, please let us know.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 02-08-2015, 04:46 PM   #7
Big hammer
Running thru the floor boards many holes would save firewall extra hole
Old 02-08-2015, 05:48 PM   #8
barkleydave
Will install probe in upper inlet hose
Old 02-08-2015, 05:49 PM   #9
Mitch//pa
the upper hose is the outlet
Old 02-08-2015, 05:52 PM   #10
barkleydave
That might work... seen a couple posts one going alone side of steering box.
Also saw a pic where someone stuck through at the terminal block but no detail on how ?
Closer to the speedo the better.
thanks for the info
Old 02-08-2015, 05:52 PM   #11
barkleydave
OOPS my mistake... O.F.S.
Old 02-08-2015, 05:53 PM   #12
Mitch//pa
i would run it through the toe board
Old 02-08-2015, 08:22 PM   #13
tbirdtbird
why use that gauge?
The dial has a very small sweep, thus is not very accurate.
The probe is mechanical, in this case filled with ether which expands with heat. Can be troublesome
Why not use an electrical sender, that way you are only running a wire
Your FLAPS will have a bunch of temp gauges to choose from. Getting a black and white face is no problem, or whatever you choose. The sender and gauge come in one box. Large sweep= much greater accuracy. Marc H. can better explain why this is than I
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-08-2015, 09:05 PM   #14
daveymc29
daveymc29's Avatar
I did the hot water test of the sender unit in my top his connection, gauge worked fine, This being a car new to me I hadn't tested it before and had never seen it move much if at all. The hot water had it shoot right up the scale and it coincided reading with a thermometer I had placed in the water. I'm good to go for a while at least. Thanks for the tips on a replacement gauge when the time comes.
Old 02-08-2015, 09:58 PM   #15
Mikeinnj
Mikeinnj's Avatar
Originally Posted by tbirdtbird View Post
why use that gauge?
What are the FLAPS that you are referring to ?
Mikeinnj is offline   Reply With Quote
Old 02-08-2015, 10:02 PM   #16
tbirdtbird
friendly
local
auto
parts
store
ie
napa oreilly autozone fredericks of oops not that one
'31 180A
Old 02-11-2015, 10:17 PM   #17
barkleydave
installed Apco gauge with under instrument panel black single mount.
Fit great and looks even better.
Was able to route through terminal box with small cutout in cover. I am not putting the light in. The OEM dash light illuminates the gauge nicely.
On to next project!
Old 02-12-2015, 08:24 AM   #18
barkleydave
Here is what it looks like.
Old 02-12-2015, 08:13 PM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
When shopping for Mechanical Temp Gages or Moto-Meters @ swap meets, take along a BIC lighter to test them with. When buying new repro temp gauges, test them in boiling water, to see if they're reading 212 degrees. Chuck went through 4 new NAPA gauges, to get one that was ACCURATE! (Made in CHINA!)
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-20-2015, 09:34 PM   #20
barkleydave
I put this apco in boiling water... it was dead on..
