Old 09-08-2014, 09:04 PM   #1
rrhorton
Default Ahoo but no Gaa
Installed my 6 volt horn with the horn resistor from Bratton's to work with my 12 volt system and pushed the horn button. After adjusting the screw on the back of the horn until just getting a good Ahoo sound, I let off the horn button. No Gaa All I get is Ahoo, Ahoo What Gives?
Spartan Horn on 31 coupe.
rrhorton is offline   Reply With Quote
Old 09-08-2014, 09:17 PM   #2
tbirdtbird
Default Re: Ahoo but no Gaa
keep fiddling with the adjustment. You'll get it
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-08-2014, 10:31 PM   #3
james hitchcock
james hitchcock's Avatar
One click at a time. Your almost there.
james hitchcock is offline   Reply With Quote
Old 09-08-2014, 10:38 PM   #4
Mitch//pa
i always put a couple drops of ATF on the armature shaft. also cooler temperatures affect the sound over warmer temps
Old 09-09-2014, 01:24 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Even tightening the cover screw makes a difference. That's why it's best to clean the commutator, oil the felts, install the rear cover, then adjust the horn. My current unrestored horn sounds best if I could adjust it right between two clicks, so as the guys have said, one click makes a big difference.
Old 09-09-2014, 09:00 AM   #6
whirnot
whirnot's Avatar
Light grease on the ends of the shaft help as well. You want the maximum sound with as little spring pressure as possible.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 09-09-2014, 09:38 AM   #7
abachman3
abachman3's Avatar
Make the adjustments with the engine running as that changes the output as well.
abachman3 is offline   Reply With Quote
Old 09-09-2014, 09:59 AM   #8
TDO
TDO's Avatar
Clean everything with WD-40 , than oil the felts .
TDO is offline   Reply With Quote
Old 09-09-2014, 01:29 PM   #9
P.S.
I found that synthetic motor oil is best for the end of the shaft and the felt. Lasts a lot longer that way too.
P.S. is offline   Reply With Quote
