Old 07-09-2024, 12:04 PM   #1
Russell Reay
Russell Reay's Avatar
Default Cowl light assembly
I am installing the turn signal kit to my cowl lights, and cannot find a sketch of the bucket assembly. What is the correct position of the gasket---under the reflector, under the lens, or under the outer rim ?
Russell Reay is offline   Reply With Quote
Old 07-09-2024, 08:57 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Cowl light assembly
Under rim like your headlights.
www.whidbeymodelaclub.com
Old 07-09-2024, 09:02 PM   #3
Gary WA
Gary WA's Avatar
Under rim like your headlights.Goes on front of reflector.
Old 07-10-2024, 07:30 AM   #4
Badpuppy
Between reflector and lens to keep the bulb dry, both cowl and head lights.
Old 11-09-2024, 11:57 AM   #5
duke36
Snyders says between outer stainless rim and lens if read correctly, not between lens and reflector. The gasket on the reflector would ride on the lens clips if the latter position ?
Old 11-10-2024, 10:16 AM   #6
Badpuppy
I stand by my previous statement. Otherwise there could be leakage between lens and reflector. Same for the tail light, although the cross bar on that gasket does nothing.
