Old 10-09-2016, 09:04 PM   #1
Sanddoc
Smile markings
Hello
I see a "52 flathead" on CL
he says it's a Merc, but gives no other info.
He does show a picture with a stamping of 52 in a square and a
2 H next to it.
Any Idea about the engine... it's been dissembled I did count
24 studs, and no extended bell-housing
thanks
Sanddoc is offline   Reply With Quote
Old 10-09-2016, 09:10 PM   #2
flatjack9
flatjack9's Avatar
Default Re: markings
The markings mean nothing to the public.
Old 10-09-2016, 10:07 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The numbers don't indicate the year.
It's weird because of the head studs installed.
It may be a Merc. engine based on the 1CM stamping on the crank.
If the carb. and heads are original it's not a 52'.
Old 10-09-2016, 10:23 PM   #4
Sanddoc
51 Merc
Thanks for the info
Think I'll take a drive out there and look at it..
$400 is not bad,
Old 10-09-2016, 10:47 PM   #5
RalphM
RalphM's Avatar
If it's got a good 4" crank, that's worth $200.00 by itself.
RalphM is offline   Reply With Quote
Old 10-09-2016, 10:51 PM   #6
Sanddoc
This one just came on line
looks like a crack next to the valve
http://losangeles.craigslist.org/wst...821058390.html
Old 10-09-2016, 10:54 PM   #7
RalphM
RalphM's Avatar
The tranny will make a good boat anchor!
Good news is that crack is easily repairable with a new seat, new sleeve and pinning the block.
Old 10-09-2016, 11:22 PM   #8
Sanddoc
to tell you the truth I need another project like a need a hole in the head...
but would like to have a Flathead, but If I do go for it, I think the 8cm is the
one..
Old 10-10-2016, 07:40 AM   #9
Ol' Ron
Ol' Ron's Avatar
Just remember, the heads and intake, as well as all the other bolt on stuff is interchangeable. The big difference between a ford and Merc is the crankshaft. However in this day and age, the block is the most important part of the engine. A good one is worth it's weight in Gold.
Old 10-10-2016, 11:14 AM   #10
Bob C
The hogs head on that 4-speed is probably worth $100-$150.
Bob
