Old 01-07-2015, 12:10 AM   #41
Smog Tech
Smog Tech's Avatar
Default Re: Installing LED stoplights?
I have Snyder's LED tail lights in my Model A. Ran the red wire between the divider and the tail light housing. I like having both top and bottom lighting up for stop light and turn signal, much easier to see.
Smog Tech is offline   Reply With Quote
Old 01-07-2015, 02:39 AM   #42
Gus
I like your light. Do you happen to know the specs of the LEDs you used? Lumens? MCD? I want to make something similar as a lightbar in the back window. Do you have a 6 volt pos ground? Thanks
Gus is offline   Reply With Quote
Old 01-07-2015, 06:55 AM   #43
Patrick L.
Patrick L.'s Avatar
I think I read somewhere the 6v were 90 candlepower.
Old 01-07-2015, 06:25 PM   #44
Patrick L.
Patrick L.'s Avatar
Until you get yourself a test light and figure out how to use it, why not just plug the left light[6v] in the right side and see if any of the lights come on.
If the lights worked a week ago you probably just have a bad connection/ground.
Old 01-07-2015, 06:42 PM   #45
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
The packaging for the passenger side LED was labeled 6 volt when actually the LED itself was labeled 12 volt. I have a proper 6 volt replacement coming from Snyders, that should be the end to the problem.
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 01-07-2015, 07:57 PM   #46
Patrick L.
Patrick L.'s Avatar
OK fine. Just making a suggestion as I thought you wanted to get this figured out as quickly as you could.
Old 01-07-2015, 08:31 PM   #47
31 Model A
31 Model A's Avatar
I did. Bob noticed one board was marked 12 volt which pretty much solved the problem although I'll feel better when the proper 6 volt LED arrives Friday and I get it installed.
Old 01-07-2015, 09:00 PM   #48
Patrick L.
Patrick L.'s Avatar
Old news. I was referring to post #36.
Boy, I can't wait to see what happens with the signals.
Old 01-07-2015, 09:13 PM   #49
31 Model A
31 Model A's Avatar
That makes two of us.
Old 01-07-2015, 09:17 PM   #50
RonC
RonC's Avatar
the led kit that you install behind your original lense looks the most stock. If you look close you can see the led bulbs behind the stock lense when off. When they light they light red and the red is so bright it shows as a red light through the stock amber portion of the lenses. Also I found cutting the wire gave a more defined tail light brake light action.
The best light I think is the complete tail light assembly with installed led lenses. They look "like" stock to the casual non model A observer but they are as bright as modern tail lights if that is what you are looking for.
RonC is offline   Reply With Quote
Old 01-08-2015, 11:53 AM   #51
Big John
Is the right side old bulb ok? time to get a test lite from napa or?
Big John is offline   Reply With Quote
Old 01-08-2015, 08:24 PM   #52
Cool Hand Lurker
Cool Hand Lurker's Avatar
The difference in the number of LEDs on the two boards is used for tail light / brake light change in brightness. For 6 volt, six LEDs wired in series will create a bright light but seven LEDs will create a dimmer light for all seven. So under normal running conditions with only the tail light on, the wiring controls seven LEDs. When the brakes are engaged, the power wire bypasses the 7th LED so that only six LEDs are activated. Those six LEDs are then brighter and function as the brake light. The fact that there are three extra resistors means there are three circuits of seven LEDs on the board for the brake light.
I think......
Cool Hand Lurker is offline   Reply With Quote
Old 01-08-2015, 11:05 PM   #53
Bob Johnson
Bob Johnson's Avatar
I thought that each LED requires 2-3 volts to operate. If you have 6 connected in series each one is only going to have about 1 volt. I do not see how 1 volt can light an LED. I have experimented with some high powered LEDs and at 1 volt they do not give off any light. ????
Bob
Bob Johnson is offline   Reply With Quote
Old 01-09-2015, 11:24 AM   #54
Cool Hand Lurker
You are right, Bob. I made up some LED lights for my trailer and it was 12 Volt. For 6 Volt Model A tail lights I used only 3 & 4 LEDs in series. My brain was operating at the higher voltage when I made the post.
Old 01-09-2015, 06:14 PM   #55
31 Model A
31 Model A's Avatar
Done Finished Fix.................I have two LED tail/stop lights now. Onward!!!!!!!!
Old 01-09-2015, 06:25 PM   #56
Mitch//pa
Yahoooooooooo
job well done
Old 01-09-2015, 07:44 PM   #57
31 Model A
31 Model A's Avatar
Originally Posted by Mitch//pa View Post
Yahoooooooooo
job well done
Not without all the help from all you here.
