Old 06-28-2025, 03:35 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Does anyone have a wiring diagram for signal-stat 900 turn signal kit?
I'm installing a signal-stat 900 turn signal assembly in my 29 wagon. I bought it used several years ago. It came with no wiring diagram. Can anyone share one?
Thanks, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 06-28-2025, 03:41 PM   #2
Default Re: Does anyone have a wiring diagram for signal-stat 900 turn signal kit?
There is a wire with the flashing unit on it and a fuse assembly. Which side of the junction box should I attach it to?
There are 2 wires that go to the brake switch. Does it matter which side of the switch they go to? One is green and one is black.
Old 06-28-2025, 03:44 PM   #3
Why do the two wires go to the brake switch? The brake light already works?
Old 06-28-2025, 10:13 PM   #4
Ayers1
Ayers1's Avatar
The original set up was voltage came into the switch and when the pedal was pressed it went out to the stop lights. With the signal switch, IF you are using the brake lights as signal light too, then the power gets sent through the signal switch so it can dictate what light blinks and what shines as a stop light. If you are using separate lights for the signals then you can skip the brake switch.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
Old 06-28-2025, 04:23 PM   #5
Gary WA
Gary WA's Avatar
here you go
www.whidbeymodelaclub.com
Old 06-28-2025, 07:07 PM   #6
JayJay
I believe that the one that Snyders sells (with the four-way flashers) is a current model SignalStat 900. They have a wiring diagram available for download.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-29-2025, 12:53 AM   #7
Randy in ca
Randy in ca's Avatar
Neil, Here's a link to the complete 6 page installation instructions:
https://dalhems.com/f/d/f450e65244f4.../A13310A12.pdf
Randy in ca is offline   Reply With Quote
Old 06-29-2025, 06:00 AM   #8
Thank you everyone for your diagrams and advice.
I will let you know how everything goes.
