By passing voltage regulator
Need a little more info. Ford 1G, 2G or 3G.....perhaps the fault prone GM one wire? Model of car?
Bill, certified Ford nut. 2024 F-150 2018 Lincoln MKZ 2016 Focus 1961 Comet S-22 1956 Ford Crown Victoria 36 Chevy, 351C/FMX, 8", Mustang II |
No one here is going to bite.
Ryan put a muzzle on me some time ago.
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
Thread on the Hamb if using Ford Alt. https://www.jalopyjournal.com/forum/...ersion.988751/
So building a car that has not been wired as yet. Has a GM column would it be better to get a GM alternator and go that route? I have bot a GM and Ford alternators so using one or the other makes no difference other then it has a Ford engine in it.
i guess I would just see which one needs the least amount of work for brackets and belt alignment. |
Being the town electrician, I’m the guy who gets called when anyone wants to rewire their car-for free.
Get something with the GM column connector. The turn signals, brakes, possibly high/low, and flashers all go thru there. It’s the most confusing wiring in the whole damn car. Most of the rest is either spades or ring terminals. The odd Ford bullet here and there, but you can buy those (I’m thinking of the headlight/parking terminals, heater blower motor, etc.). No big deal. No matter which alternator you use, I’m not a fan of 1 wire. I like the idiot light to work (sometimes I’m the idiot) and I like the voltage delivered at the battery to be right. The 3 wire connection does all that. Any good set of instructions will have additional drawings for a variety of ignition and alternator connections. Reading them is your friend. |
