Old 10-22-2024, 04:35 PM   #1
jtucker
Default Oversize Clevis Pins
Does anyone have a list of clevis pins and standard sizes for the Model A?
Does anyone have a source for oversize clevis pins?
Trying to take some of the slop out of my rods.
Thx,
Jim
jtucker is offline   Reply With Quote
Old 10-22-2024, 05:27 PM   #2
JayJay
Default Re: Oversize Clevis Pins
Thx,
Jim
Jim - Snyder’s and Bert’s both sell the oversized pins. I suspect other vendors do as well. Standard side is 0.310” (nominal 5/16”) oversized is 0.340” (drill out your rod ends to 11/32 (0.344”)).
All the pins in the braking system, both service brake and emergency brake, are the same.
This is a worthwhile project. Suggest you just order a set of oversized pins and do everything, that way you won’t have to remember what are smaller pins and what are larger.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 10-23-2024, 03:30 PM   #3
jak
https://www.brattons.com/searchprods.asp
these have the correct profile head on them
jak is offline   Reply With Quote
Old 10-24-2024, 01:05 PM   #4
Steve Schmauch
I use an "R" size drill bit (0.340") to drill worn clevis pin holes, then I use thin-walled brass or steel tubing (brake lines material) with at 0.340" OD and 0.310" ID to bush them back to standard size. That way you do not have to drill out those original clevis holes that are still good, and you end up with all standard sized clevis pins, which in my opinion look better than the oversize ones, for those interested in authenticity (see post #3).
Steve Schmauch is offline   Reply With Quote
Old 10-25-2024, 11:21 AM   #5
The Master Cylinder
The Master Cylinder's Avatar
I like it. Thanks for the info.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
