Old 09-28-2024, 11:00 AM   #1
rbassemir
rbassemir's Avatar
Default Where does this go?
I removed all my fenders from my 1935 Ford Convertible Sedan months ago for some body work. Now I’m putting things back together and run into a problem. I took before pictures but I did not get a good one of the underside of my rear fenders. I have these brackets that should fit in the rear but none of the holes line up. I sure could use a picture or advice. I wonder if I used the rear fender brackets on the front fender (if that is even possible).
This is what the brackets look like.
Rich
rbassemir is offline   Reply With Quote
Old 09-28-2024, 11:09 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Where does this go?
Perhaps on the back of the rear fender where it connects to the body?? Or maybe bottom of grille to body?
Old 09-28-2024, 11:25 AM   #3
deuce lover
deuce lover's Avatar
They go from the body across to the tail light under the fender.Its a support and conceals the tail light wires.I could only find these illustrations from an old Drake catalog
Old 09-28-2024, 12:07 PM   #4
rbassemir
rbassemir's Avatar
Great this helps a lot!!
Rich
Old 10-02-2024, 08:15 AM   #5
rbassemir
rbassemir's Avatar
It seems obvious now, but I did not figure it out without this help.
Rich
