The Ford Barn
-   -   Where does this go? (https://www.fordbarn.com/forum/showthread.php?t=342613)
rbassemir 09-28-2024 11:00 AM
Where does this go?
2 Attachment(s)
I removed all my fenders from my 1935 Ford Convertible Sedan months ago for some body work. Now I’m putting things back together and run into a problem. I took before pictures but I did not get a good one of the underside of my rear fenders. I have these brackets that should fit in the rear but none of the holes line up. I sure could use a picture or advice. I wonder if I used the rear fender brackets on the front fender (if that is even possible).
This is what the brackets look like.
deuce_roadster 09-28-2024 11:09 AM
Re: Where does this go?
Perhaps on the back of the rear fender where it connects to the body?? Or maybe bottom of grille to body?
deuce lover 09-28-2024 11:25 AM
2 Attachment(s)
They go from the body across to the tail light under the fender.Its a support and conceals the tail light wires.I could only find these illustrations from an old Drake catalog
rbassemir 09-28-2024 12:07 PM
Great this helps a lot!!
rbassemir 10-02-2024 08:15 AM
2 Attachment(s)
It seems obvious now, but I did not figure it out without this help.
