Old 01-21-2024, 06:26 PM   #1
Randall
Randall's Avatar
Default Head gaskets v8
How big is the piston bore before having to use overbore gaskets?
Thanks
Randall is offline   Reply With Quote
Old 01-21-2024, 06:57 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Head gaskets v8
I’m thinking.080
Old 01-22-2024, 07:41 AM   #3
Randall
Randall's Avatar
thanks Ken
Old 01-22-2024, 10:04 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
I think Ken has it about right. If I was .080 or larger, then go to the big-bore versions. Also, I tend to sue the GraphTite style gaskets on street engines from Best Gasket.
Old 01-22-2024, 10:37 AM   #5
deuce_roadster
deuce_roadster's Avatar
What B&S said x2.
Old 01-22-2024, 10:49 AM   #6
Tim Ayers
Curious to why vs. copper?
Tim Ayers is online now   Reply With Quote
Old 01-22-2024, 01:47 PM   #7
Bored&Stroked
I've seen a lot less electrolysis with the composite style versus the copper-sandwich types.
Now, if you are doing other things to prevent electrolysis, then maybe not an issue. I also like the Cometic MLS gaskets - really nice product, but expensive. One nice thing is that they are available in many different gasket thichnesses.
Important! You must have the correct (pretty smooth) surface finish on the decks and heads to run MLS gaskets and not have coolant weeping.
Old 01-22-2024, 09:05 PM   #8
Pete
I use copper on all.
I run 50/50 anti freeze on the street with 1 can of Bars Leaks.
I run straight water on the track with 1 can of Bars Leaks.
I have never noted any electrolysis etching.
Old 01-22-2024, 10:35 PM   #9
kiwi nz
Why the Bars Leaks? in my past experience Bars Leaks was a good way to block radiators.
kiwi nz is offline   Reply With Quote
Old 01-22-2024, 10:40 PM   #10
Pete
Water pump lube and anti corrosion of the system.
Old 01-23-2024, 09:21 AM   #11
glennpm
glennpm's Avatar
Works well for me with no radiator problems.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 01-22-2024, 10:13 PM   #12
Randall
Randall's Avatar
Thanks to all!
Old 01-23-2024, 09:06 AM   #13
Randall
Randall's Avatar
while we are on water pumps wheres a good place to buy rebuild kits for pumps?
Old 01-23-2024, 09:25 AM   #14
glennpm
glennpm's Avatar
Since this thread has already been hijacked ...
Skip Haney
Punts Gorda Florida.
[email protected]
941-637-6698
He’s been doing it for many decades with high volume impellers.
Rumble Seat's Notes
Old 01-23-2024, 03:29 PM   #15
Randall
Randall's Avatar
Skip Haney
[email protected]
941-637-6698
Tried to call but it only beep's
Old 01-23-2024, 09:23 AM   #16
Tim Ayers
Is this the stuff we are talking about or the old fashioned tablets?
https://barsleaks.com/product/rhizex...top-leak-1199/
Old 01-23-2024, 09:30 AM   #17
glennpm
glennpm's Avatar
Yes, that's what I've used.
Glenn
Rumble Seat's Notes
Old 01-23-2024, 09:59 AM   #18
Ron_r1959
Ron_r1959's Avatar
Generally speaking, as long as your radiator is clean in the first place, it won't cause you any trouble, It gets a bad wrap from people who have a compromised radiator and then dump stop leak in it, well guess what, it will plug the radiator up then. On the other hand Trying to run a flathead with a dirty radiator isn't the best idea in the world anyway! LOL
Ron_r1959 is offline   Reply With Quote
Old 01-23-2024, 03:50 PM   #19
glennpm
glennpm's Avatar
Give this a try
https://skipscoilsandpumps.com/
Rumble Seat's Notes
Old 01-23-2024, 09:44 PM   #20
Randall
Randall's Avatar
Thanks Glen I talked with him
