Old 09-13-2021, 12:45 PM   #1
jerryt
Default what can I use?
I am about to take possession of my 1926 Ford. I know I should get the motor running but there is a thing nagging me. If I want to switch form 4 wheel drum brakes to more modern disc drum set up what can I use? The truck has a drop front axle. It has ford bolt pattern. I want to make it stop better once I get it running. Any suggestions brakes master cylinder etc.
Thanks
Jerry
jerryt is offline   Reply With Quote
Old 09-13-2021, 01:23 PM   #2
Rodrelic
Default Re: what can I use?
Drum brake are good enough for a light hot rod IMO
Rodrelic is offline   Reply With Quote
Old 09-13-2021, 02:19 PM   #3
J Franklin
J Franklin's Avatar
The model T came without any drum brakes.
Old 09-13-2021, 03:58 PM   #4
jimTN
Model T's did not have 4 wh drum brakes, they had a transmission brake and a parking brake in the rear drums. It sounds like you have a mixture of parts not Model T.
Old 09-13-2021, 11:40 PM   #5
jerryt
Yes my truck is kind of frankensteined. Im just thinking forward for things to fix and replace.
Thanks
Jerry
Old 09-14-2021, 09:02 AM   #6
rotorwrench
rotorwrench's Avatar
We would have to know what front and rear axle you have to be able to give much advice. If it's model A then a person would need to know what fits that set up as well as the modifications to get it there. There is a lot of information on the HAMB forum for modification of early Fords of the various model years but they would need to know what you have as well.
