I have an 8BA stock rebuilt { Walt Dupont} engine. It has run great, and still runs great except for 1 issue which just started. Taking off in 1st and 2nd gear , and winding her up, high revs the engine cuts out . If I dont wind it up it runs fine, no issues in 3rd gear. I have changed the points and condenser and timed it. Any help here would be great! Kind regards Ray
Starving for fuel?
#3 | |
![]() Quote:
Stock fuel pump ? How old ? Tank and lines in good condition ? |
Valves sticking a little. Needs a dose of
Marvel Mystery Oil. G.M.
www.fordcollector.com |
I have inspected the fuel line which looks fine, stock fuel pump 6 years old with about 4000 miles on it.The tank is clean. The 1 thing I noticed when under the hood revving the engine and letting off there is bubbles coming from the top of the pump into the glass bowl. not sure this is normal , as I said it runs great as long as I dont get into it and drive normal. I'll try the MMO also. Thanks for the info guys Ray
Any results on this issue?
Air leak in the flex line, going to the fuel pump.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
Why do you mention a Walt DuPont engine ? Your problem doesn't appear to be because of Walt DuPont's work. You seem to have a fuel delivery problem.
#10 | |
![]() Quote:
Probably so we won't question the engine build since most of us know Walt's stuff is done correctly. That eliminates a lot of questions! Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
I've been gone for a bit will get to looking at this soon. The reason I mentioned Walt was to state that it was a stock rebuild, and no other reason. Thanks Cadillac 512. Walt is the best
My 8BA was experiencing the same "cutting-out" at higher rpms and I replaced the vacuum advance canister. It ran great after that!
Pat |
