Old 07-10-2020, 11:12 PM   #1
Steve Plucker
Default Correct horn rod push button tension spring...
I have two types of horn rod push button tension springs.
One is a barrel type spring, the other is a tapered spring.
Both could be used to keep the horn push button from coming in contact with the area to Ahooga the horn when not pressed.
Which is original and correct to use?
Thanks.
Pluck
Old 07-11-2020, 05:32 AM   #2
Werner
Werner's Avatar
Default Re: Correct horn rod push button tension spring...
Guten Morgen Pluck,
under my horn button (1928, 7-tooth) was a barrel-shaped coil spring.
But I can not say that this is original, because it could be seen that the button was previously opened.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-11-2020, 06:14 PM   #3
Steve Plucker
Thanks Werner and yes...it is a barrel shape spring.
Pluck
