Old 06-14-2020, 07:05 PM   #1
DBSHELTON
Default Crank Hole
My crank hole in the radiator shell and the guide doesn't line up with the front pulley. Not sure where to start trying to make everything line up. Antone run across this problem?
DBSHELTON is offline   Reply With Quote
Old 06-14-2020, 07:19 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Crank Hole
A common issue. I would start with trying to adjust the front motor mount by tightening the nut to bring it down or loosening it to bring it up. Thats if you have a stock mount with correct parts.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-14-2020, 07:46 PM   #3
katy
katy's Avatar
Also check the rear motor mounts.
Old 06-15-2020, 07:31 AM   #4
Dean Lemoine
Dean Lemoine's Avatar
I just sort of went through that situation. I installed a reproduction radiator shell and found the crank wouldn’t fit. The hole in the shell was slightly too high. I had another crank with a smaller diameter shaft, now it fits fine.
Dean Lemoine is offline   Reply With Quote
