Old 10-01-2019, 09:29 AM   #1
chrs1961815
chrs1961815's Avatar
Default Roadster Top Won't Go Up?
Ever since I replaced the stanchions and frame with originals the top hold downs will not fit on the stanchions. The top bow is original. Doesn't seem to line up vertically or horizontally. 28 Roadster
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-01-2019, 09:57 AM   #2
JBill
Default Re: Roadster Top Won't Go Up?
Can you get enough play by loosening the stanchions and moving them around a little to get the top seated, and then tightening them back down? Or are they too far off even for that? Horizontal I can get. But the vertical being off is puzzling. Let us know what happens.
JBill is offline   Reply With Quote
Old 10-01-2019, 10:29 AM   #3
chrs1961815
I tried loosening the wingnuts but I can also try the screws.
Old 10-01-2019, 10:36 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
While that may be true, it sure does not seem that way. It sounds like poor craftsmanship from a former restorer is creating stress for you now.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-01-2019, 11:26 PM   #5
chrs1961815
Thematically, that fits in with the rest of the PO's "restoration." What can be done?
Old 10-03-2019, 10:18 AM   #6
chrs1961815
Tried loosening the screws but to no avail. New top and restoration of bows?
Old 10-04-2019, 03:47 AM   #7
Dodge
Put the old stanchions back on.
Dodge is offline   Reply With Quote
