Roadster Top Won't Go Up? Ever since I replaced the stanchions and frame with originals the top hold downs will not fit on the stanchions. The top bow is original. Doesn't seem to line up vertically or horizontally. 28 Roadster
Re: Roadster Top Won't Go Up? Can you get enough play by loosening the stanchions and moving them around a little to get the top seated, and then tightening them back down? Or are they too far off even for that? Horizontal I can get. But the vertical being off is puzzling. Let us know what happens.
Re: Roadster Top Won't Go Up? Quote:
While that may be true, it sure does not seem that way. It sounds like poor craftsmanship from a former restorer is creating stress for you now. |
Re: Roadster Top Won't Go Up? Tried loosening the screws but to no avail. New top and restoration of bows?
Re: Roadster Top Won't Go Up? Put the old stanchions back on.
