Old 11-20-2018, 07:21 AM   #1
JD 1931
JD 1931's Avatar
Default leaking shut-off
Replaced original shut off valve with a repro about 10 yrs ago and now it is leaking. The repro looks same as original and how is it to rebuild? leak is very small.
JD 1931 is offline   Reply With Quote
Old 11-20-2018, 08:21 AM   #2
WHN
Default Re: leaking shut-off
Replace!
Ten years, it doesn’t owe you anything.
Even a small gas leak is a problem. Enjoy.
Old 11-20-2018, 10:38 AM   #3
DHZIEMAN
The best choice is replace it, In my opinion! Gasoline can be dangerous, best to assure NO LEAKS!
DHZIEMAN is offline   Reply With Quote
Old 11-20-2018, 10:46 AM   #4
whirnot
whirnot's Avatar
I will be the contrarian, I would rebuild it. Take it apart, sand the surfaces lightly with 600 to 800 grit sand paper, clean it well and lap it with white toothpaste. Will be good for years to come.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-20-2018, 10:54 AM   #5
Redbird
Redbird's Avatar
Agree with above. Rebuild it!
Redbird is offline   Reply With Quote
Old 11-20-2018, 11:30 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I would first try tightening the packing nut a small amount and observe the results . If the packing nut is tightenbed too much it will lock up the valve . If tightening the packing nut didn't solve the problem I would replace the cut off valve .
Old 11-20-2018, 01:57 PM   #7
30 Closed Cab PU
Had this problem. tightened nut, then Rebuilt once, then replaced twice - still leaked
https://www.fordbarn.com/forum/showt...ight=gas+valve
Barn recommended replacing with Brattons part #13160 - issue solved. Made in the USA, 3 year warranty. Most others are made overseas.
Another possibility is to find an original - try rebuilding it.
https://www.brattons.com/fuel-shut-o...-gas-tank.html
Old 11-21-2018, 08:32 AM   #8
ryanheacox
ryanheacox's Avatar
Thats the valve I got. Had to put a die on the threads to get it to line up correctly but other than that it works perfectly.
Old 11-21-2018, 10:12 AM   #9
30 Closed Cab PU
Info on your original question.
Not sure why, most posts I've seen shy away from rebuilding repop shutoffs,. Other Barners recommend finding an original to rebuild. Here is a u-tube video, personally have not used the video, there may be other u-tube videos.
https://www.youtube.com/watch?v=SRIc2GDj_yQ
Old 11-20-2018, 05:51 PM   #10
rocket1
I hope you saved the original,rebuild it.
rocket1 is offline   Reply With Quote
Old 11-20-2018, 11:23 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
I agree. I rebuild my 1929 valve more than 20 years ago, and it's still leak free.
Is the leak external, or is it down the line past the tapered valve?
Always use the small screen in the valve, to keep out junk.
Old 11-21-2018, 10:31 AM   #12
ryanheacox
ryanheacox's Avatar
Yep, I posted not long ago about rebuilding a repro valve and all responses were "it's not worth it".
Old 11-21-2018, 11:20 AM   #13
JD 1931
JD 1931's Avatar
thanks for the info, I order a rebuild kit for my old original valve today..
Old 11-21-2018, 12:47 PM   #14
Cape Codder
Cape Codder's Avatar
I have always wondered REALLY what is the purpose of the shut-off valve? Was it because Henry thought there would be a lot of trouble with the Zenith carb.? The reason I say this is I know of a gentleman that never turns his shut-off off when just parking or putting it away in the garage. He has never had leakage at the carb. nor shut-off valve.
Cape Codder is offline   Reply With Quote
Old 11-21-2018, 01:55 PM   #15
J Franklin
J Franklin's Avatar
If you leak 10 gallons of gas on the ground you will know why the shut-off is there. Maybe the Ford Co. lawyers came up with this! It only takes a speck of dirt to hold the needle valve open. If when you shut the car down and there is no leak at the carb there may be evaporation over time that will allow gas into the carb and maybe also dirt.
