Old 04-13-2018, 05:34 PM   #1
old31
Default Would you use this coil?
Is this coil good for continued use?
The primary check of the 2 poles shows 2.3k. The specs call for 1.0-1.4.
The secondary shows at 15.5k. The spec shows 5.8k-9.2k.
old31 is offline   Reply With Quote
Old 04-13-2018, 07:57 PM   #2
Doug Linden
Doug Linden's Avatar
Default Re: Would you use this coil?
If you have over 2k on the primary and the spec is for 1-1.4 ohms, then no, replace it.
Doug Linden is offline   Reply With Quote
Old 04-14-2018, 08:59 AM   #3
old31
Thanks.
Old 04-14-2018, 09:25 AM   #4
katy
katy's Avatar
Try it, not hard to swap in a coil for testing, you may like it.
How accurate is your meter?
Old 04-14-2018, 09:27 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A Guy, unknowingly, put a 6 Volt coil on a 12 Volt Dodge! GREAT SPARK, 1/2 Hour later, it EXPLODED, COPPER FUZZ & OIL, everywhere! Worse thing, it wuz a FLATBED & nobody had a FLATBED thet could haul it!!!
Bill Waitingforantipainpilltokickin
"THE ASSISTANT GURU OF STUFF"
Old 04-14-2018, 11:49 AM   #6
barkleydave
barkleydave's Avatar
Folks forget that a 1.4 ohm coil must use a external ballast resistor then it is fine for a 12V system.
Now note a cheap ohm meter usually is not accurate enough to measure the Ohms correctly.
barkleydave is offline   Reply With Quote
Old 04-14-2018, 09:25 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, especially when you try to measure less than about 5 ohms.
Old 04-14-2018, 09:46 PM   #8
J Franklin
J Franklin's Avatar
What should the added resister read? I just put a 12 volt battery in my 6 Volt tractor and was planning on buying a coil. maybe I can just make the modification.
Old 04-14-2018, 10:34 PM   #9
Tom Wesenberg
Use a 1 1/2 ohm coil rated for at least 30 watts or more. Auto stores should have something in stock.
