Old 05-17-2017, 03:10 PM   #1
Mike/Nebraska
Default head studs
Just curious about how many of you use loctite or a dab of gasket sealer?
Mike/Nebraska is offline   Reply With Quote
Old 05-17-2017, 04:11 PM   #2
denniskliesen
denniskliesen's Avatar
Default Re: head studs
No sealer on mine. I used antiseize on mine the last time.
denniskliesen is offline   Reply With Quote
Old 05-17-2017, 04:20 PM   #3
Beauford
Nothing on mine but antiseize is a good idea if they break off.
Beauford is offline   Reply With Quote
Old 05-17-2017, 06:42 PM   #4
Big hammer
If the stud hole goes through to water, you'll need thread sealer. Thread sealer with teflon will make it easier to remove later !
Big hammer is online now   Reply With Quote
Old 05-18-2017, 09:44 AM   #5
100IH
I would not use Locktite.I have never heard of studs unscrewing themselves at the block. If one should break down the road, it would only make re-moveable more difficult than it already is. Permatex #2 sealer will coat the threads and deter rusting and getting tighter over time. Sealer of some kind is a must on the wet holes so coolant does not weep up the stud, through the bore in the head, to the nut. If antisieze is used, it is not a sealer, so Permatex is needed at the wet holes. The studs need not to be torqued to seat them in the block. Take them down to the stop and then back off 1/4 turn. Someday, you will be glad you did.
100IH is offline   Reply With Quote
