Old 08-28-2016, 06:12 PM   #1
brum1
brum1's Avatar
Default Is the quality that poor??
Replaced several 6v bulbs in one of my cowl lights in the past few months(same side) Is the bulb quality that poor these days or should I be looking for something else? Bulb tight in socket.
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 08-28-2016, 06:33 PM   #2
C26Pinelake
Default Re: Is the quality that poor??
The quality may not be outstanding but it would be prudent to check the socket and the circuit. Wayne
C26Pinelake is offline   Reply With Quote
Old 08-28-2016, 06:48 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
When I'm BORED, I sit in the house & watch bulbs BURN out! Then we go to the door & watch the GRASS/WEEDS grow.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-28-2016, 07:49 PM   #4
J Franklin
J Franklin's Avatar
Make sure the bulb sockets are clean and shiny and also well grounded. Older bulbs were usually marked 6-8 Volt, new ones are only 6 volt.
Old 08-28-2016, 09:12 PM   #5
Special Coupe Frank
Special Coupe Frank's Avatar
The new production Asian bulbs are not very long-lived, especially headlamp bulbs.
Try to score NOS at swap-meets and e-bay when you can.
Also make sure all connections and contacts are clean and good, especially any circuits that depend on the chassis to be the ground-return.
What # bulb are you using in the cowl-lights ? The lower wattage bulbs should last longer, and if you're using them for just a parking light, you don't need something bright like an 1129 or 1156 (if 12-volt).
Special Coupe Frank is offline   Reply With Quote
Old 08-28-2016, 10:49 PM   #6
ian Simpson
Get #63's from NAPA. They are rated at 7 volts.
ian Simpson is offline   Reply With Quote
Old 08-28-2016, 06:37 PM   #7
mike657894
mike657894's Avatar
if your battery is not getting good connection your voltage from the generator can spike and burn out your bulbs. clean your contacts. I bought a 10 pack of bulbs off ebay for 10$. because I cant stand to pay 5$ for 2 bulbs at the autozone.
mike657894 is offline   Reply With Quote
