Can you guys tell me if this is a Model T? Or what it might be?
https://goo.gl/photos/58hfvMGYTdmLqZcq8 https://goo.gl/photos/PEg5GDPKfiCLnQL27 |
No Ford had a cowel vent before 1933. Plymouth Pontiac no enough left for ID
26-27 Ford had a cowl vent,,,,,
While I am waiting for photo to down load. There were cowl vents on the 1924/25 closed cars (coupe, tudor and fordor). For 1926/27 only the fordor had the cowl vent the coupe and tudor had the gas tank under the cowl. I would have to check but I think the later closed TT (ton truck) had cowl vents also. Some of the early fordor Model A's had vents in the side of the cowl.
I could not down load the photos. Could you post them here? |
#9 | |
![]() Quote:
Not Model T. T's did not have that large of a cowl or the bright trim band. The rounded rear roof is also not Model T.
Looks like a Pontiac, about 1930 - 31. Not much there.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
#13 |
#14 |
I'm thinking Model A...
Barnstormers VSC- Celeritate Est Vita Battery Fabrication Technologist- Ford Motor Company Antique Vehicle Mechanic- Greenfield Village Sometimes Docent - Ford Piquette Avenue Plant Member #347- Early Ford Registry rileyracing on the HAMB |
#15 |
Or maybe 32 Chevy looking at the cowl...
#16 |
A T would look like this...
#17 |
Most definately not a FORD car. Looks like about 1929/30 but can't say what make.
Adjust your points with gentle blows of a 2 pound hammer ![]() |
#18 |
Theres a spare sidemount well in the passenger side fender. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" |
#19 |
Dash looks a lot like 1928-29 Hudson.
#20 |
Hudson looks to be the most plausible. Not a Ford, regardless there is a value once you get an ID.
