Old 01-23-2016, 04:56 PM   #1
Charles Reese
Charles Reese's Avatar
Default E28-Floor Weather Pad (S Column)
Like so many others… bad case of cabin fever here in mid-Atlantic … going through my “A” photos while I still have power.
Would appreciate comments as to the correct shape and installation of A-35122-AR FLOOR WEATHER PAD. I apologize to anyone I should acknowledge for the attached photos-early in my collecting I failed to record my sources.
A: possibly an original pad? Seems to have been previously (crudely) installed. However, the original molded areas for screws were not used (and are a very different shape than other examples). Note the ‘flange' around the 3 edges IS a uniform size.
B: reproduction (don’t recall source). ‘oval’ shape of molding around pedals. ‘Flange’ around the 3 edges is NOT uniform size.
C: reproduction (popular vendor). Pedal holes similar to original; oblong screw holes. ‘Flange’ around the 3 edges is NOT uniform size.
D: reproduction (popular vendor). “Someone” assumed the thin flanges around the edges were left over from the molding process … trimmed them off …now feel they should remain and be tucked under floor mat/carpet … expensive lesson learned Anyone interested in a ‘modified’ repro?
** Would much enjoy any photos of original pads
Stay warm and safe!!
Charles Reese is offline   Reply With Quote
Old 01-23-2016, 05:21 PM   #2
Steve Plucker
Default Re: E28-Floor Weather Pad (S Column)
Interesting to have vendors go to all the trouble to make B, C, and D when they could of copied an original and be done with it.
Interesting samples Charles.
Is "A" of solid rubber or is there a cloth reenforcement within?
Pluck
Old 01-23-2016, 05:34 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
Pluck
Steve,...I thought it had a piece of "sheet metal", with the rubber molded
around it..
d.j. moordigian is offline   Reply With Quote
Old 01-23-2016, 05:52 PM   #4
Steve Plucker
around it..
You are right DJ!
Pluck
Old 01-23-2016, 05:39 PM   #5
Charles Reese
Pluck
i've not seen an original...
The JS say: "There was a pyramid patterned rubber pad (weather seal) with a metal core around the steering column. "
(assume similar to later style 2-piece)
Old 01-23-2016, 05:30 PM   #6
Pinesdune
Pinesdune's Avatar
Here's what came in one of my boxes for m'lady, I imagine it's original, but who knows
Looking for the front bumper emblem that has "Ford, Made In Canada"
Pinesdune is offline   Reply With Quote
Old 01-23-2016, 05:35 PM   #7
Pinesdune
Pinesdune's Avatar
Here's another pic with a piece that fell off the bottom corner, my car is a March 28 Canadian built
Old 01-23-2016, 06:08 PM   #8
Charles Reese
intersting "orphan" hole (drilled?) in right side of mounting area ... purpose?
Old 01-23-2016, 06:35 PM   #9
Pinesdune
Pinesdune's Avatar
I have no idea, I didn't take it apart and there's no sign of it purpose looking at the floorboards
Old 01-23-2016, 05:46 PM   #10
d.j. moordigian
If you look at #5, top of the photo,..you can see the metal inner structure..
Old 01-23-2016, 05:56 PM   #11
Charles Reese
Again, I apologize for not having source info ....
this pix suggest the 2-piece plates are embedded ... but could be he's just comparing
Old 01-23-2016, 06:02 PM   #12
2manycars
2manycars's Avatar
The original that I have has the metal moulded into the whole pad, like the photo in post #5, where you can see the metal sticking out by the pedal holes, where the rubber has been broken off.
2manycars is offline   Reply With Quote
Old 01-23-2016, 06:08 PM   #13
Charles Reese
can you kindly post pix? (NEVER too many pix of original items!!)
Old 01-23-2016, 10:22 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
In 2000 I bought a repro plate from Bratton's, and it has the metal plate molded in, just like my original. My original was in bad shape, but I saved it somewhere.
I'll look around for it, but don't hold your breath.
Old 01-24-2016, 12:59 PM   #15
SteveB31
SteveB31's Avatar
Years ago a flimsy repro was made with no metal inside. It was 70s - early 80s. About 15 years ago we acquired several nice originals and made a mold using them as the example. We have made and sold 1700 of them, and are the only ones that have made them in the last 30 years. The have a metal reinforcement inside as do all of the original ones. We make these one at a time by hand as well as numerous other exact copies for other rubber parts such as Cabriolet (both 68B and 68C) and Sport coupe landau iron spacers? Iwill tame some photos Monday and post here.
Steve Becker
Bert's Model A Center
SteveB31 is offline   Reply With Quote
Old 01-24-2016, 01:01 PM   #16
Steve Plucker
Steve Becker
Thank you Mr. Becker!
Pluck
Old 01-24-2016, 01:06 PM   #17
DougVieyra
DougVieyra's Avatar
Thanks for the post Steve, and for all the effort you put in this (and many other) project. It is MUCH appreciated by the Model A community.
DougVieyra is offline   Reply With Quote
