Old 10-09-2015, 01:17 AM   #1
Lawrie
Lawrie's Avatar
Default 33 loose sterring problem
After driving about 100klms last April on the worst dirt road ever the 33 steering got a little loose,and coming back from out west last Saturday it was a pain to drive at 55 on the capricorn highway,what with rough road due to the heavy truck traffic,a strong cross wind , and wanting to get home for the footy final.
so today I thought I would readjust up the steering box,got it up on the axle stands and found the nut holding the pitman arm onto the sector shaft was loose,
took it off and cleaned up the spline ,reassembled it with loctite super retaining compound and torqued it up.
Hey preto back to nice steering.
One thing I,m paranoid about is the steering box,as to get a good right hand drive one is nearly impossible.
So if you do a lot of miles,check this nut.
Lawrie
Old 10-09-2015, 03:26 AM   #2
koates
Default Re: 33 loose sterring problem
Lawrie, the pitman arm nut originally should have a large strong spring washer under it to prevent it coming loose. The Loctite might be an overkill and also make it difficult to remove at a later date unless you use some heat on it which I would not really like to do. Regards. Kevin.
koates is offline   Reply With Quote
Old 10-09-2015, 04:43 AM   #3
Lawrie
Lawrie's Avatar
Kevin, there was no lock washer,now it has ,
my fault,20 od years ago when I got the 33 it was loose then and I put a large washer under the nut and lockwired it,I was going to fix it properly but clean forgot,lucky I got it before it buggered the spline.
Lawrie
Old 10-09-2015, 08:31 AM   #4
KiWinUS
KiWinUS's Avatar
Lawrie I may have a RHD 33-4 box or parts can't remember exactly what . I will look when I get home from work today .
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 10-09-2015, 03:21 PM   #5
Lawrie
Lawrie's Avatar
Thank you tony, I would be most interested.
Lawrie
Old 10-09-2015, 08:42 PM   #6
Kpar
Kpar's Avatar
When you do find it Tony, I'll race Lawrie to to the delivery van as I'd like to have a spare R/H box to rebuild also.
keith
Kpar is offline   Reply With Quote
