Old 09-13-2015, 07:43 AM   #1
rob63mess
rob63mess's Avatar
Default pan gasket set
I got the pan gasket set from Snyders. There are 2 identical pieces in it that are about 1/4 by 3/8 by 5 inches long. One goes between the rear main cap and the pan .... where does the other one go?
rob63mess is offline   Reply With Quote
Old 09-13-2015, 08:09 AM   #2
john charlton
john charlton's Avatar
Default Re: pan gasket set
There are two different rear main caps which take the cork seal for 28/29 use the 13/32" wide and for 30/31 use the 3/8" wide . But if your engine has been replaced/rebuilt you should check the width of the cap seal width .
John in damp rainy Suffolk County England
Old 09-13-2015, 10:58 AM   #3
rob63mess
rob63mess's Avatar
Thanks John.
