Old 08-16-2014, 07:11 PM   #1
JackA
JackA's Avatar
Default clutch adjustment problem
I had to take the pedals out to replace the steering column, When I try to adjust the clutch, the adjuster seems too long. When adjusting it is going further on the threads than it ever was before. It seems like something has slipped. The fork looks close enough to the throwout bearing. What is going on?
JackA is offline   Reply With Quote
Old 08-16-2014, 07:45 PM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: clutch adjustment problem
did your return spring brake. On the throw out bearing housing.
Gunmetal blue2 is offline   Reply With Quote
Old 08-17-2014, 07:52 AM   #3
V4F
V4F's Avatar
the throw out brg may have moved when you took the pedals out . check the inspection hole on the bell housing .......
V4f
V4F is offline   Reply With Quote
Old 08-17-2014, 03:58 PM   #4
Ed in Maine
The fork on the throwout bearing is not seated properly. Open inspection cover and move the fork left or right to get it on the throwout bearing. I had the same experience. Ed
Old 08-20-2014, 04:29 PM   #5
JackA
JackA's Avatar
V4F and ED nailed it the release bearing hub is rotated. I don't know how to get it back without potentially breaking something. Please help! I attached a photo to show what is going on.
Old 08-20-2014, 10:41 PM   #6
Dan Partain
Dan Partain's Avatar
Try this -
1. Take the pin out of the adjusting clevis on the clutch adjusting clevis to free it from the clutch pedal.
2. Let the clutch lever drop down, that will put the forks to the rear.
3. Remove the spring on the throw out bearing hub. At this point I think you will be able to push the throw out bearing hub forward and then turn it so it locates into the forks properly. If necessary, you could pry the throw out hub forward a little. I think you'll be able to do it without prying though.
4. Replace the spring on the throw out bearing hub.
Dan Partain is offline   Reply With Quote
Old 08-20-2014, 11:44 PM   #7
redmodelt
redmodelt's Avatar
Or just pull the fork back and use a screw driver to pop it back into place. Leave the spring on, they are a "B" to replace.
Old 08-21-2014, 12:06 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Yep ! If there was room for it to get out of "WHACK", there's room to get it BACK in "WHACK"!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-21-2014, 06:04 PM   #9
JackA
JackA's Avatar
Many thanks to Dan, Red, and Bill! Without your help it would still be not fixed. Dan, I used your advise and used the pedal for leverage and felt it release, then a few whack's with a hammer and punch, the hub went back to where it belonged. This forum is a modern wonder.
Old 08-21-2014, 06:08 PM   #10
BILL WILLIAMSON
FORD BARN'S the greatest invention since PEANUT BUTTER! We have SO much FUN, tryin' to "HELP"!
Bill W.
