I would like to convert my 35' coupe to juice brakes and wondered if anyone made a set of pre bent brake lines? Any information would be appreciated.
Thanks Dan |
Dan. Have you thought of installing energizers? They're about $56 and work just as well as hydraulics.
WILL and WILLIT..... Are you guys related????
(626) 338-2282. He furnished everything we needed for our 34 and 36 5 window coupes. Fit like they came from factory!! |
I plan on buying Richards master cylinder mouting bracket but I thought his price for brake lines was bit high at 395.00. I can make my own but thought if I could buy a pre bent set reasonable I would go that route and be done with it.
C&G Early Ford Parts sells the energizers(floaters).Part#48-2043. $54.95.
Their phone number is 1-800-266-0470. I put them on my '36 and I'm very pleased.It might be worth looking into Dad. |
My 35 coupe has juice brakes. You can buy the brake lines for a 39' and they will be much cheaper. Check Spadero or Early Ford V8 in SC.
The early V8 garage master cylinder mount is pretty simple to fabricate. I used his pics as a reference and saved a bunch of money on my 34 pickup. My 35 coupe has a 39 pedal assembly. You will still need to mount the conectors and go thru the inner fender panels for the hoses etc. |
#10 | |
![]() Quote:
Did you do the master with the bell crank that mounts sideways to the frame? |
Read number four site how do I know
#13 |
Brake lines are a walk in the park to bend up out of the softer cupro nickel tube . It still complies with all regulations and bend and flares real nice.
#14 | |
![]() Quote:
#15 | |
![]() Quote:
Just curious, but why are you running the lines on top of the frame rails? It may be easy and look good, but there's not a lot of room between the body and frame, and smashed/damaged lines may result, as this routing is not normal. Also, the rear frame to axle flex line looks too short to allow full axle jounce and rebound, but that might be just the picture. ![]() |
#16 | |
![]() Quote:
#17 |
Mr. Will,
You've got a very nice looking build going on, and am glad you have checked critical areas/items. ![]() ![]() |
#18 |
I put brake floaters on my '35 fordor sedan last spring and they made a huge difference in how this car brakes. I have driven cars with hydraulic brake conversions, using '39-'48 components, that did not stop as well as my car stops now. The new Lincoln brake offers may be a different story.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-22-2014 at 09:35 AM. |
#19 |
What kind of brake floaters do you have? Just curious.
#20 |
I agree with my4dv8 on the cupro nickel brake line. Got mine at CARQUEST. beautiful bends with a bender or just use your fingers. Double flares are no problem with a basic double flaring tool.
