Old 02-02-2014, 05:55 PM   #1
tudoor
Default new transmission gears
I am rebuilding my transmission, and I am wondering about the quality of the new gears on the market? Need to replace the top shaft, first, and second gears and all the bearings. Thanks.
tudoor is offline   Reply With Quote
Old 02-02-2014, 06:40 PM   #2
Mitch//pa
Default Re: new transmission gears
I assume when you say top shaft you mean the input shaft (main shaft)?
The gears sold by the suppliers from my experience are of good quality. Make sure they state made in USA. Stay away from any offshore stuff. I recently replaced my input only and it worked well with no abnormal problems or noises.
I also use the one sided sealed bearings ( debatable topic like oil) and the shafts with the orings.
Old 02-02-2014, 08:27 PM   #3
Growley bear
My shafts and gears were made in Denmark, very high quality. I took the shift tower off at 2000 miles and they aren't even scratched. Got them from Mike's.
Chet
Growley bear is offline   Reply With Quote
Old 02-03-2014, 03:21 PM   #4
plind
plind's Avatar
Chet
Hi Growley Bear...
I am quite surprised that there is such a thing made ​​in Denmark ... I know much is being done out of quality on all machined thing ..Have never heard about making Gears for Model A. But are you able to remember where in Denmark they are made and what the company name was ..?
Per,
www.forda1927.dk
Tudor * A 2820 *
Town Sedan * A 4472283 * Orig.never restored.
plind is offline   Reply With Quote
Old 02-03-2014, 09:31 PM   #5
Growley bear
Originally Posted by plind View Post
Hi Growley Bear...
Per,
I asked the vendor before I bought them and that is what I was told. I figured that parts made in Denmark had to be of high quality.
I don't know where in Denmark though.
Chet
Old 02-03-2014, 10:03 PM   #6
montanafordman
montanafordman's Avatar
I rebuilt my transmission a couple years ago and bought a new USA made input shaft/main gear, new cluster gear, and a new low reverse gear. I also replaced all the bearings and the idler and cluster shafts with the o-ring ones. I kept my idler gear and 2nd/high gear since they were in good shape. I don't have enough experience with other model A's or NOS gears to know if mine makes any more noise than normal but it seems to work great in my experience (about 2,000 miles). Naturally if you can find all NOS gears that's the way to go but its going to be extra time or money and maybe both. If you can find good original gears your mileage may vary if you're mixing ones with different amounts of wear. Of course I did this too by mixing my new gears with my used 2nd/high gear and reverse idler but all seems ok. I stuck with the USA made gears and visually they looked well made and a good fit and visually near identical to the originals they replaced. The one (out of two) sliding gears I replaced fit just right on my output shaft and wasn't too tight or two loose and I had no issues with the cluster gear or main shaft either. I don't feel that its too noisy and it doesn't slip out of gear at any time.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 02-02-2014, 08:47 PM   #7
Pete
Try Mac at this URL. Good guy to deal with.
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Old 02-02-2014, 10:25 PM   #8
glenn in camino
glenn in camino's Avatar
back in 1969 I bought all the gears, shafts, bearings, etc for my first Model A restoration at a local Model A parts vendor for $80. My impression at the time was Wow, that's a lot of money to spend on a Model A. I still have that car and the trans. operates perfect.
Old 02-03-2014, 10:09 AM   #9
Ford1931
Ford1931's Avatar
I bought a Mitchell sychronized transmission and sent them the case minus the internals. The gears look perfect. If some one is interested I would sell all for $150
262-694-0519
Ford1931 is offline   Reply With Quote
Old 02-03-2014, 02:18 PM   #10
jm29henry
jm29henry's Avatar
mikes sells a totally rebuilt original trans for under $700.00 dollars what the parts cost you may want to concider it plus a warrenty
jm29henry is offline   Reply With Quote
Old 02-03-2014, 04:53 PM   #11
Brian T
Brian T's Avatar
It is not rebuilt it is brand new, gears and casing etc what does that tell you?
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 02-04-2014, 03:24 AM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
I knew a guy that replaced his tranny gears because he thought the pointed teeth meant they were shot. This is the pointed ends on the teeth that helps them to slide together easier.
Old 02-04-2014, 06:18 AM   #13
Tom Walker
Tom Walker's Avatar
Hi, please can you let us have a link to the supplier you are calling "mike". Thanks, Tom.
Tom Walker is offline   Reply With Quote
Old 02-04-2014, 06:38 AM   #14
Mike V. Florida
Mike V. Florida's Avatar
Mikes Afordable www.mikes-afordable.com
Old 02-04-2014, 01:35 PM   #15
J Franklin
J Franklin's Avatar
I see the all new transmission from Mike's is under $600. I think these are made in Denmark.
