Has anyone seen this before, must be a late 29
It's an early 1930 used on commercial and trucks until the body change in mid 1930.
It may also have the 1930 pattern steering wheel/headlight switch/steering column.
It probably has Budd 5 hole wheels and the front spring is 2-1/2 wide. (Earlier were 12 or 18 leaf car width front springs.) Its like Ford made just enough changes to use up the Squarish Budd Bodies before the swap over to the Ford produced "cab." https://aafords.com/cabs/82-a-closed-cab/ Joe K
Shudda kept the horse. |
It does have a 30 wheel.
This one looks "rustic." Do you have any more pix?
Joe K
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
It is not a 1929 it is an early to June 1930 when Ford changed the commercial line from the 1929 to 1930 cab and sheet metal .The 82A cab to the 82B cab . This truck had the heavy brakes,bevel back axle and BUDD 5 hole wheels .
John in very hot humid Suffolk County England . |
