The Ford Barn
-   -   29 AA fuel tank with a 30-31 fuel cap (https://www.fordbarn.com/forum/showthread.php?t=350325)
Shelbycsx 06-29-2025 02:15 PM
1 Attachment(s)
Has anyone seen this before, must be a late 29
Bob C 06-29-2025 02:28 PM
Re: 29 AA fuel tank with a 30-31 fuel cap
It's an early 1930 used on commercial and trucks until the body change in mid 1930.
Joe K 06-29-2025 03:34 PM
It may also have the 1930 pattern steering wheel/headlight switch/steering column.
It probably has Budd 5 hole wheels and the front spring is 2-1/2 wide. (Earlier were 12 or 18 leaf car width front springs.)
Its like Ford made just enough changes to use up the Squarish Budd Bodies before the swap over to the Ford produced "cab."
https://aafords.com/cabs/82-a-closed-cab/
Joe K
Shelbycsx 06-29-2025 04:21 PM
It does have a 30 wheel.
Joe K 06-29-2025 05:39 PM
This one looks "rustic." Do you have any more pix?
Joe K
Chris Haynes 06-30-2025 12:31 AM
It is an Early 1930, not a Late 29. All 1929 style sheet metal with all the new 1930 Suspension, Brakes, Wheels, ETC.
john charlton 07-01-2025 10:31 AM
It is not a 1929 it is an early to June 1930 when Ford changed the commercial line from the 1929 to 1930 cab and sheet metal .The 82A cab to the 82B cab . This truck had the heavy brakes,bevel back axle and BUDD 5 hole wheels .
John in very hot humid Suffolk County England .
