Old 02-28-2025, 05:20 PM   #1
GPierce
GPierce's Avatar
Default Differential Vent
Anybody with a Mitchell overdrive using YAPP Studios Differential vent?
https://www.secretsofspeed.com/diffy-vent
GPierce is online now   Reply With Quote
Old 02-28-2025, 10:49 PM   #2
radiation
Thumbs up Re: Differential Vent
Originally Posted by GPierce View Post
Anybody with a Mitchell overdrive using YAPP Studios Diffy vent?
I have one installed for my Volvo overdrive!
radiation is offline   Reply With Quote
Old 02-28-2025, 10:50 PM   #3
whirnot
whirnot's Avatar
Default Re: Differential Vent
The vent that comes with the overdrive works fine, why not use it?
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 03-01-2025, 02:20 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
I think he is asking about a vent for the rear end, not the O/D.
Tom Endy has an article on this. https://www.santaanitaas.org/wp-cont...ntial-Vent.pdf
That's me and my rear end he is referring to. Pictures are of my rear with vent.
Old 03-01-2025, 05:09 AM   #5
Bruce of MN
Bruce of MN's Avatar
My version. I decided I wanted to keep the vent vertical. It will make lubing the shaft there a bit more work, but now no drips at the rear wheels.
Old 03-01-2025, 12:39 PM   #6
Ray in La Mesa
I did the same but used a 45* angle fitting and screwed a Zenith float valve into it.
Ray in La Mesa is offline   Reply With Quote
Old 03-01-2025, 04:44 PM   #7
Bruce of MN
One of these?
https://www.brattons.com/ORIGINAL-ST...uctinfo/14300/
Was the 45 a pipe fitting? How did you adapt it?
Old 03-02-2025, 01:09 AM   #8
Ruth
That sounds interesting. Do you have a picture of that?
Ruth
Old 03-01-2025, 06:58 PM   #9
duke36
Install the Endy vent on the passenger side away from the large banjo gear.
Old 03-01-2025, 10:58 PM   #10
Ray in La Mesa
Yes, like that but a repro. I don't know what the fitting size is but it was in my box of brass fittings.I got lucky as the threads on the float valve matched the brass fitting. I don't think it is a pipe fitting.
Old 03-02-2025, 10:52 AM   #11
GPierce
GPierce's Avatar
Originally Posted by ray in la mesa View Post
yes, like that but a repro. I don't know what the fitting size is but it was in my box of brass fittings.i got lucky as the threads on the float valve matched the brass fitting. I don't think it is a pipe fitting.
1/8 npt
Old 03-02-2025, 03:19 PM   #12
Benson
1. Model A Zenith FLOAT VALVE is 1/2 20 (NOT pipe thread)
Old 03-04-2025, 04:14 PM   #13
Synchro909
Synchro909's Avatar
I tried drilling a vent through one of the bolts that hold the trumpets on. I put it at the top on the side opposite the crown wheel and the hole facing up. There must be a lot of oil being thrown about in there because it leaked a lot so I made another with a small plastic tube on it (like Mitchell uses on their O/D) and secured the open end up near the spring mount in the cross member I left plenty of slack in it to allow for the movement of the axle. Much better!
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-04-2025, 05:08 PM   #14
Y-Blockhead
I did the same and it still pushed oil out the tube. That is when I decided to use the Alemite vent on the axle tube. Never a drop now.
