Old 09-04-2017, 08:13 PM   #1
lautens
Default 1931 Model A starter
Bendix hangs up on ring gear. Thought I resolved it by adding a shim. Drove the car on a one week tour and never had any problems. Tonight went on a 15 mile dive, stopped for supper and of course tonight it hung up. With the limited tools I had with me I got it unbolted, but it usually won't let go without some persuasion. But no punch or hammer tonight. Put in neutral and used the crank handle and gave it a yank and it let go. Put it back together and it's good to go again. Someone once told me that a Ford 9N Bendix will work better. Any suggestions other than tearing out the motor?
lautens is offline   Reply With Quote
Old 09-04-2017, 08:21 PM   #2
RawhideKid
Default Re: 1931 Model A starter
You can also place it in third and rock the car back. That will work most of the time.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 09-04-2017, 08:32 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Rubbing the flywheel teeth with Wheel Bearing Grease helps prevent lots of HANG-UPS. Lurned this on Jaguars, the Older ones used a similar Bendix.
Bill Metricandwhitworth
"THE ASSISTANT GURU OF STUFF"
Old 09-04-2017, 08:43 PM   #4
Smooth_One
Smooth_One's Avatar
Bill I'm going to try this and hold you responsible.. ha ha!
Isaiah Bigmess
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 09-04-2017, 09:37 PM   #5
BILL WILLIAMSON
Isaiah Bigmess
But it prevents RUST, inside the Bell Housing
Bill Schlickery
Old 09-04-2017, 08:38 PM   #6
Jacksonlll
Jacksonlll's Avatar
Dont be a wimp when you push on the starter button. If you push on it, let it up and push again quickly, that will hang it up. Push hard and dont let up until it starts. If you do let up, let things quiet down before pushing again.
Old 09-04-2017, 08:41 PM   #7
Smooth_One
Smooth_One's Avatar
Mine hangs up some times and as Rswhidekid said I put it in 3rd rock it back and it usually comes loose.
Better than pulling the starter each time.
Isaiah B.
