Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
As you can see in the photo................
![]() How can that be fixed? Ed
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
Put a piece of rubber hose for a splice.
MY PROBLEM CHILD! ![]() |
that would be easiest way...
I can do that!!!!!!
I'm finding that Sarah is no....Virgin!!!! ![]()
You don't want a virgin. Those with experience are much more FUN.
Places that repair air conditioners have sleeves that can be soldered. Or bring it to a radiator shop - you could drive there if you don't mind getting your firewall all dirty. Make friends with the guy and he'll likely fix it while you wait and do it for free. Give him a ride afterwards. Joe K
Shudda kept the horse. |
#6 | |
Hey all part of the fun being the caretaker of these 83+ year old ladies... I keep in mind what caretaking I might need if I'm blessed to last that long...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
It shouldn't be too hard to solder in a complete new tube.
If you want to repair this tube, and looks are important, then you could buy a short piece of thin brass tube from a hobby store and solder it to the inside of the pipe and solder the splice seam smooth. You'd have to clean the inside of both pieces very well so the solder sticks to them as well as the brass splice. |
so someone duped you into thinking you were getting an 83 year old virgin lol
however you decide to fix it atleast use the hose for a temp fix or youll have a real mess when the fan slings it all over the place 1/4" fuel will work and fit on tight Last edited by Mitch//pa; 11-18-2014 at 08:31 PM. |
Use black plastic heatshrink tubing.
Thanks gentlemen.................info and advice greatly appreciated!!!!
#13 |
Do you happen to know how it got broken, in that location on the rad, in the middle of the line and a clean break ?
Wayne Last edited by C26Pinelake; 11-19-2014 at 10:25 AM. |
#14 |
Nope!!! But I plan to make sure the lower half is not plug before I slip on a sleeve to join them. I know the upper portion is clear....found out when I put in that quart night before last. I didn't notice it then where the overflow exited from.
#15 |
It's clear..............
#16 |
The plastic sleeve is a bit too small. Have to get a size larger next time out to fix the overflow line. I did get the radiator fluid changed. What came out was quite dark green and heavy. Almost looked like straight Anti-Freeze. A small amount of rust was at the end. Filled it to the baffles.
