A while ago a wrench was discussed to get at that pesky head bolt under the distributor. How many of you have the common Ford wrench that has one end for the plugs and the other end for the head nuts. I have several. I decided to make my own version of the reaching wrench to allow torquing the head nut, as well as allowing access to torque the head nuts or bolts under the oil filter on the early V8s. What better tool steel could be found? Pictured is a before and after of how I made my wrench. I did have to cut a 1/2" ratchet extension top off to add the 1/2" drive end of the tool. I used an end of a impact extension from HF. Some quick welding finished off the tool to attach the 1/2" drive end.
I bought a new one from Brattons .
I don't have one of those original tools, in fact very few over here do so I made one by cutting a socket (I think you guys call them a box wrench) in half and welding a piece between the two halves. Result: a tool to do the job and a 1/2" drive at the top so I can use the torque wrench.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
Arizona Model A have them , great idea , saves pulling the dissy ,
Russ, very clever, and well done! Around here those original wrenches usually sell for $5 if your lucky enough to sell it. Think I'll grab one of my spares and do the same as you.
Hope I won't infringe on any copyright you have for the design! ![]() Thanks for posting this very handy hint. Jeff
Let's let pylons, be pylons! |
#7 | |
![]() Quote:
#8 | |
![]() Quote:
I have a bunch of these (genuine Snap-On) if anyone is interested, send me a PM.
#10 | |
![]() Quote:
Did you ROB a Snap-On Truck? ![]() I'd visit my Snap-On Friends' Home & he had BOXES & BOXES of USED tools, didn't know where he got them & didn't ASK! Bill Equipped
I forgot to mention the main reason why I decided to make my own tool. When torquing head fasteners, I prefer to use a 6 point socket.
I have found that this is the best tool for the job. With the others you can't use a torque wrench. http://www.snydersantiqueauto.com/he...e-tool-adapter
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#13 | |
![]() Quote:
#14 |
I am sure it does. I'll also bet it is much more expensive.
#15 | ||
![]() Quote:
As to the cost: you get what you pay for.
#16 |
ALL this for 1 head nut? You're NOT going to torque it 4 TIMES a day! With NO distributor cable clamp, it's a 5 MINUTE job.
Bill W.
#17 |
I am getting up there Bill, but I'm not yet ready to give up my flathead tinkering.
#18 | |
![]() Quote:
#19 |
That nut can be EASILY "torqued" with a long OPEN END/BOX END wrench, with an " estimated" 55 Ft Lbs force. Example, it's easy to tighten lug nuts to 55 Ft Lbs, using the crank. THAT ONE HEAD NUT IS NOT A BIG DEAL!!!
Bill Commonsense
#20 |
Bill, no matter how long you beat that drum, the fact is, some people just like tools.
