The Ford Barn
-   -   Head nut under the distributor (https://www.fordbarn.com/forum/showthread.php?t=238662)
Russ/40 02-05-2018 03:25 PM
1 Attachment(s)
A while ago a wrench was discussed to get at that pesky head bolt under the distributor. How many of you have the common Ford wrench that has one end for the plugs and the other end for the head nuts. I have several. I decided to make my own version of the reaching wrench to allow torquing the head nut, as well as allowing access to torque the head nuts or bolts under the oil filter on the early V8s. What better tool steel could be found? Pictured is a before and after of how I made my wrench. I did have to cut a 1/2" ratchet extension top off to add the 1/2" drive end of the tool. I used an end of a impact extension from HF. Some quick welding finished off the tool to attach the 1/2" drive end.
Purdy Swoft 02-05-2018 04:20 PM
Re: Head nut under the distributor
I bought a new one from Brattons .
Synchro909 02-05-2018 04:26 PM
I don't have one of those original tools, in fact very few over here do so I made one by cutting a socket (I think you guys call them a box wrench) in half and welding a piece between the two halves. Result: a tool to do the job and a 1/2" drive at the top so I can use the torque wrench.
quickchange 02-05-2018 06:11 PM
Arizona Model A have them , great idea , saves pulling the dissy ,
JDupuis 02-05-2018 06:27 PM
Russ, very clever, and well done! Around here those original wrenches usually sell for $5 if your lucky enough to sell it. Think I'll grab one of my spares and do the same as you.
Hope I won't infringe on any copyright you have for the design! :).
Thanks for posting this very handy hint. Jeff
denis4x4 02-05-2018 07:45 PM
A set of crows foot wrenches in 3/8” or 1/2” drive should be in all tool boxes
CarlG 02-05-2018 08:11 PM
1 Attachment(s)
I have a bunch of these (genuine Snap-On) if anyone is interested, send me a PM.
BILL WILLIAMSON 02-06-2018 07:02 AM
Carl,
Did you ROB a Snap-On Truck?:confused:
I'd visit my Snap-On Friends' Home & he had BOXES & BOXES of USED tools, didn't know where he got them & didn't ASK!
Bill Equipped
BillLee/Chandler, TX 02-06-2018 09:44 AM
Have you ever figured out how much a crow's foot changes the actual torque applied to the nut? Maybe not much, but they do make a difference.
denis4x4 02-06-2018 11:26 AM
At best, it's a minimal difference, especially if you use the crow's foot and the same torque values on all of the nuts.
Russ/40 02-06-2018 02:03 PM
I forgot to mention the main reason why I decided to make my own tool. When torquing head fasteners, I prefer to use a 6 point socket.
Chris Haynes 02-06-2018 02:20 PM
I have found that this is the best tool for the job. With the others you can't use a torque wrench. http://www.snydersantiqueauto.com/he...e-tool-adapter
CarlG 02-06-2018 03:59 PM
The SnapOn tool uses a torque wrench.
BILL WILLIAMSON 02-06-2018 04:04 PM
ALL this for 1 head nut? You're NOT going to torque it 4 TIMES a day! With NO distributor cable clamp, it's a 5 MINUTE job.
Bill W.
Russ/40 02-06-2018 05:45 PM
I am getting up there Bill, but I'm not yet ready to give up my flathead tinkering.
Chris Haynes 02-07-2018 12:58 AM
I am sure it does. I'll also bet it is much more expensive.
CarlG 02-07-2018 08:37 PM
The point was: "With the others you can't use a torque wrench." is not a true statement.
As to the cost: you get what you pay for.
katy 02-08-2018 10:40 AM
If the crow's foot is at a 90° to the wrench, the torque is the same as the wrench setting.
BILL WILLIAMSON 02-08-2018 05:28 PM
That nut can be EASILY "torqued" with a long OPEN END/BOX END wrench, with an " estimated" 55 Ft Lbs force. Example, it's easy to tighten lug nuts to 55 Ft Lbs, using the crank. THAT ONE HEAD NUT IS NOT A BIG DEAL!!!
Bill Commonsense
Russ/40 02-08-2018 07:08 PM
Bill, no matter how long you beat that drum, the fact is, some people just like tools.
