I am going to replace the gas shutoff valve on my 31 s/w town sedan with indented firewall. What is the recommended sealant to use on the threads where it screws into the outlet of the gas tank?
... oops. wrong thread.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() Last edited by 700rpm; 03-19-2021 at 10:16 PM. |
I would use gasoila. You can get it at tractor supply.
Good things take time |
I use Permatex 59214 Thread Sealant. No reason for the "High Temperature", it was what was available at my local auto parts store. It has worked well, I had one shutoff valve that was leaking and it sealed it up fine. I keep the tank dry for at least 24 hours after screwing in the valve to let the sealant have a chance to set. I have not had luck with so-called "teflon tape" in gasoline applications, the gasoline seems to dissolve the tape.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
Is that the stuf w/teflon in it?
I suspect that some flavor of Locktite would also work, but Locktite is a different product - polymethyl methacrylate compound, aka Super Glue. Not typically used on tapered fittings like the gas valve. JayJay
I use Permatex! Never had a problem. However had problems with new petcocks not being of quality and them leaking! Sad situation on some parts and in this case a safety issue.
