Old 03-31-2022, 09:43 AM   #1
art ebeling
art ebeling's Avatar
Default 1936 hubcaps
Can the 1936 hubcaps be taken apart? I would like to get to the backside of the chrome or stainless center cap to remove some dents. Thanks, Art
art ebeling is offline   Reply With Quote
Old 03-31-2022, 09:51 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 hubcaps
Re: 39 pickup wheel color ?
When I was restoring hubcaps for my 1936 pickup, I drilled my small hole in the back side to be able to use air pressure to pop the stainless cover off. While several that I did were black paint under the stainless, several others were production body colors. So, there is "evidence" that hubcaps in 1936 were painted in body colors.
I copied and pasted this from another thread.
Old 03-31-2022, 12:58 PM   #3
rockfla
rockfla's Avatar
As Sheldon had wisely advised, small 1/8 or 3/16th hole in the cap with compressed air blowing behind the cap BUT "IF" the is bucket part of the cap has ANY rust hole, it will NOT work!!! You are then stuck destroying the "bucket" to get the cap off!!!
Old 03-31-2022, 01:04 PM   #4
art ebeling
How is the quality of the reproduction 36 hubcaps? Art
Old 03-31-2022, 01:27 PM   #5
rockfla
rockfla's Avatar
I'm not a "36" guy SO I cannot answer your question......I do the above posted all the time with 39 Mercury Caps.....with that said, IF you are hesitant about doing the above process or have an Issue, send it to me and I will pop it off for you!!!! Straighten the cap & polish it , IF You like......OR just pop it off and I will send it back!!!
Old 03-31-2022, 03:13 PM   #6
nelsb01
nelsb01's Avatar
There are still lots of 1936 hubcaps out there.
As stated -- slowly drill a hole in the center from the back side. Fill a cardboard box with towels or blankets and use an air nossle to blow the stainless off. Send the stainless to a company or person that specializes in stainless work. Sandblast the steel cap and when painting, spray the area that shows with 2 coats, spray the area where the stainless goes with one coat. Apply a thin coat (repeat -- thin coat) of vasilne around the edge of the stainless before attempting to stamp stainless back on the cap.
I created a stainless mold of 4 inch pink foam insulation and then framed it with 2 by 6 boards with a 3/4 in plywood top. Placed the stainless over the steel cap, place waxed paper over the stainless and them placed my mold over the wax paper, stainless and steel cap.
Used my large foot to stomp the mold and the stainless was in place. The wax paper leaves a little residue, but that is easily removed.
nelsb01 is offline   Reply With Quote
Old 03-31-2022, 03:15 PM   #7
nelsb01
nelsb01's Avatar
Picture #2
Old 03-31-2022, 03:18 PM   #8
rockfla
rockfla's Avatar
OR
You can heat the SS cap in the oven and put the "shell/bucket" in your freezer. Should drop right on and let both equalize to ambient temperature.
Old 03-31-2022, 04:28 PM   #9
art ebeling
Thank you for the offer and I may take you uo on that. I just got the four that came with the project truck out of the box and two of them are not 36 hubcaps. The stainless part does not have an ring around the outside edge , just smooth caps. I will let you know when I can get a good full set together. I am also considering reproductions if I can get some good reports on them. Art
Old 03-31-2022, 05:51 PM   #10
36coupe
36coupe's Avatar
I would say go with original. I don’t think they are hard to find. I have some repo ones on my 38 and they are one piece all chrome, not great quality.
36coupe is offline   Reply With Quote
Old 04-03-2022, 09:15 PM   #11
26 lakes
Here is an in depth step by step discussion on restoring the stainless hub caps.
https://www.fordbarn.com/forum/showthread.php?t=267941
26 lakes is offline   Reply With Quote
Old 04-03-2022, 11:24 PM   #12
Tinker
Tinker's Avatar
Please copy to this thread on colors. Or where you posted the "evidence". I would appreciate it.
