Hi FBer's
Today, worked on the brakes on my 28, getting ready for spring. The car is up on jackstands and I did all of the preliminary work on brake rods, clevis pins, shaft and pedal bushings, return springs and lubricated all. Did not take off the brake drums because did that last year when I lubricated the bearings. What I found is that the left side parking brake handle (with the single brake system) can be used instead of a graduated block, holding down the brake pedal. The ebrake has four ratchet clicks from zero. Useful for trying different brake positions for adjusting the pegs on the backing plates. On my car, I have set up so that the brakes lock on the second click of the ebrake handle. This equates to half-way down pedal position. It may be that many of you know this, if you have the left brake handle. I found it a lot easier than messing with the board on the pedal routine. Now for a road test!! Hoping for some nice weather to go driving. Regards, Martin Mindling Watertown, Ohio (where we keep 'em between the fence posts). |
(WELL! looks like I just ended ANOTHER thread! Should I become PARANOID, again?) Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 03-09-2013 at 06:42 PM. |
